Valve grind kit question?? Can anyone answer? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-04-2009, 04:00 AM Thread Starter
Powerstroke.org Acolyte
Question Valve grind kit question?? Can anyone answer?
Hi everyone. I am going to do the head stud change on my 2003 F350 with the 6.0. I found this kit on ebay.
FORD 6.0 L DIESEL ENGINE 18mm HEAD GASKET SET 2003-04 on eBay.ca (item 190340472525 end time 07-Nov-09 09:56:10 EST)
Item #190340472525 if the link doesn't work.
Can anyone tell me if that is the proper kit for my engine? The dowel size, etc? Anyone have any good or bad experience with this seller?
Thanks in advance!!
2003 Ford F-350 King Ranch Crew Cab Short Box, 6.0L Powerstroke, DashDAQ, custom rear diff cover, DIY egr delete, air cleaner, fumoto drain valve, DIY coolant filter, JVC NX7000 Nav system Sirius/Bluetooth, remote start/alarm, spray in box liner, DIY Britebox and custom power feed, DIY High Idle, big HFCM drain plug,
Egmonster is offline
post #2 of 4 Old 11-04-2009, 04:21 AM
Lt. Negativity
RescueF250's Avatar
Dont buy anything for your 6.0 that involves your motor on ebay. It can be the worse thing you ever do. Do it right and contact a more reliable vendor. Also those are head bolts your looking at not head studs. It would be pointless to put head bolts back in just get a set of ARPS or H-11.
Matt at Gearhead,Doug at GoGo,Dave at Diesel Innovations,Ryan at Full Force Diesel,Eric at Innovative. Adam at First Coast
Built 2003 with 04.5-07 parts,Hey its a hybrid
Totaled
New Era Rescue 08 F250 CC/SB No limit stuff, H&S stuff, Fl pro stuff.
RescueF250 is offline
post #3 of 4 Old 11-04-2009, 05:17 AM Thread Starter
Hay thanks for that. Oh poo. I suppose you are right.
I know those are head bolts. They come with the valve grind kit. I was just going to get him to toss them in the garbage to save on shipping. Sigh.. I guess I will look into getting it at a proper dealer.
Thanks for the comeback.
post #4 of 4 Old 11-04-2009, 11:52 AM
03ccf350's Avatar
i bought mine off ebay and it was fine. i will get the number for you.
CLARENCE
2003 F-350 6.0
HOMEMADE EGR DELETE, MBRP, QUADZILLA GAUGES, ARP'S, 4.5" ICON LIFT,TUNED BY INNOVATIVE, DJ'S, AND CALE.
03ccf350 is offline
