What do you think about this Oasis report? - Ford Powerstroke Diesel Forum
Old 11-03-2009, 07:39 PM
So I am thinking about buying an 03 250 and was wondering what everybody thought about this Oasis report? Looks like the turbo got replaced in 07 and the tech I talked to said it was probably replaced with an 07? Is that correct or would they happen to have an 03 turbo left over? Interested to hear if you think this is a good truck to buy?
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTSW31P53EC76556 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 25-MAR-2003 11-APR-2003 124427 USA 7 2G05 031405 * RECAL * D36 82 15999
AWS Claim Key: 3096451 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01200 - * Name: NICK NICHOLAS FORD, INC. Ph: 352-7261231 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-2003 Doc #:08857351
Cust Comments: CUST STATES TRUCK HAS ROLLING IDLE
Tech Comments: DIESEL DIAGNOSIS DIAG ANDREPAROGRAM PCM RETEST
1FTSW31P53EC76556 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 25-MAR-2003 11-APR-2003 124427 USA 39 2E06 030008 3C3Z 9E527 AE D36 42 65191
AWS Claim Key: 13884736 Trx Code: E72 Labor Hrs: 7.2
Dlr Cd-Sub Cd: 04735 - * Name: NICK NICHOLAS FORD-LINCOLN-MERCURY Ph: 352-7957371 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:30-MAY-2006 Doc #:08235751
Cust Comments: RUNS ROUGH & WATER IN FUEL LIGHT IS ON CK&ADV
Tech Comments: REPLACED # 2 & 3 INJECTOR THAT FAILED, ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIA
1FTSW31P53EC76556 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 25-MAR-2003 11-APR-2003 124427 USA 39 2E06 030008 3C3Z 9E527 AE D50 D8 65191
AWS Claim Key: 13894166 Trx Code: E88 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04735 - * Name: NICK NICHOLAS FORD-LINCOLN-MERCURY Ph: 352-7957371 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:30-MAY-2006 Doc #:08235752
Cust Comments: INJECTOR WILL NOT SEAL
Tech Comments: WOULD NOT SEAL REPLACED #2 INJECTOR, RECHECK OK
1FTSW31P53EC76556 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 25-MAR-2003 11-APR-2003 124427 USA 39 * * * * * * * 65191
AWS Claim Key: 13884733 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04735 - * Name: NICK NICHOLAS FORD-LINCOLN-MERCURY Ph: 352-7957371 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:30-MAY-2006 Doc #:08235740
Cust Comments: 04S15 NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK CONNECTION
Tech Comments: RECALL 04S15 REPLACED BOLT
AWS Claim Key: 13884734 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04735 - * Name: NICK NICHOLAS FORD-LINCOLN-MERCURY Ph: 352-7957371 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:30-MAY-2006 Doc #:08235741
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: RECALL CUSTOMER ASSURANCE TEST DRIVE REPLACE
AWS Claim Key: 13884735 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04735 - * Name: NICK NICHOLAS FORD-LINCOLN-MERCURY Ph: 352-7957371 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:30-MAY-2006 Doc #:08235742
Cust Comments: 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: RECALL REPROGRAM PCM, TCM, AND FICM
1FTSW31P53EC76556 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 25-MAR-2003 11-APR-2003 124427 USA 48 2E06 03XXXX 2C3Z 9G804 AB L65 D8 88038
AWS Claim Key: 14895682 Trx Code: E72 Labor Hrs: 4
Dlr Cd-Sub Cd: 04735 - * Name: NICK NICHOLAS FORD-LINCOLN-MERCURY Ph: 352-7957371 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2007 Doc #:09021651
Cust Comments: CUSTOMER STATES CHECK FOR OIL LEAK
Tech Comments: HI PRESSURE PUMP LEAK REMOVE HI PRESSURE PUMP RESEAL FITTINGS AND REPLACE BASE GASKET
1FTSW31P53EC76556 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 25-MAR-2003 11-APR-2003 124427 USA 52 2H01 030407 3C3Z 6K682 CBRM D50 42 87107
AWS Claim Key: 15347247 Trx Code: E72 Labor Hrs: 13
Dlr Cd-Sub Cd: 04735 - * Name: NICK NICHOLAS FORD-LINCOLN-MERCURY Ph: 352-7957371 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-JUL-2007 Doc #:09407151
Cust Comments: CUSTOMER STATES NO POWER AND RUNS ROUGH AFTER WARMED UP
Tech Comments: REPLACED TURB, ICP SENSOR, AND EGR VALVE, REPROGRAMMED PCM SENSOR INJECTION CONTROL PRESSURE (ICP) REMOVE AND INSTALL OR
Old 11-04-2009, 06:18 AM
Anybody out there that could give me some info?
Old 11-04-2009, 06:29 AM
Doesn't look to bad. Headgaskets arent on there which could be a good or bad thing.
Old 11-04-2009, 06:40 AM
Yeah I figure it will need head studs and gasket's eventually after I get the truck. What about the turbo being replaced? Would it be replaced with another 03 or would it have a new one on it?
Old 11-04-2009, 07:06 AM
it should be an 03, but the best way to tell is to listen to that baby scream haha it has a very distinct whistle. even with muffler on you should still be able to tell.
Old 11-04-2009, 10:34 AM
how do i go about getting one of these for my truck? do they cost money? can someone on here get it to me? hoep someone can help..
sorry for stealin your thread, but it looks pretty good
Old 11-04-2009, 10:55 AM
subscribing for this answer
Old 11-04-2009, 10:58 AM
You can get them at a Ford dealer and I think they are free. Premium members can get Oasis reports but Dave cant run Oasis reports right now.
Old 11-04-2009, 11:46 AM
I have a friend who is a Ford tech and I got him to run it for me.
