Exhaust Mod???? - Ford Powerstroke Diesel Forum
Old 11-03-2009, 06:31 AM
Send a message via Skype™ to NoNtypical10
Exhaust Mod????
Just curious on how its done. I am looking to buy either a 4 or 5 " mbrp system for my truck, and have seen some run it out right before the rear tire. Is this a kit, or just shortening the pipe, and adding a few new hangers. Anyone have or done this? Thanks for the info..
Old 11-03-2009, 07:28 AM
I have seen it done, and it's done just like you said. But the only thing to worry about and its not a big deal would be the mess of exhaust soot you would get on your rim especially if your running a tune.
Old 11-03-2009, 08:27 AM
Save your money on buying a kit and just buy a new Down Pipe. From there go to a truck shop and get some 4" or 5" pipe with a reducer to connect to your down pipe. Then get a 45* or a 90* bend and run it out in front of your tire. It's pretty easy, and you can do it for a fraction of the cost of buying a kit and modifing it.
-French
Old 11-03-2009, 08:29 AM
I had mine cut up from my stock unit. Loved it as far as the sound but it was way to aggravating having to clean soot off the wheel all the time. Taylor (taylorking) has no trouble out of his IIRC.
Old 11-03-2009, 08:46 AM
i did it on my d max before i bought the duels but there is no kit to do this i just shortened up pipe and cut and welded my own bends it is way louder then behind tire almost as loud as stacks
Old 11-03-2009, 07:17 PM
thanks guys, knowing a little bit more helps, not sure which route im going, just love the way it looks
Old 11-03-2009, 08:25 PM
Actually seen a truck the other day that was using 4" flexi-exhaust ducting all the way thru...must have been using his orig downpipe with an adapter to the 4" flexi---and the rest is a no brainer...pretty slick and easy if you ask me.
