Adrenaline HPOP Upgrade
What is the purpose in upgrading the HPOP on 6.0 to one like the Adrenaline HPOP the make for the 6.0's?
Here is a link to this HPOP 2003-2004 6.0L Dieselsite Adrenaline High Pressure Oil Pump (HPOP) - Diesel Performance Parts |
looks like more volume oil or something. If you are trying to build more power or something. Larger injectors etc. But then i read down further, they are still testing it.
They say you can be a beta tester. Personally, if it aint broke, I wouldnt fix it. Or wait till they have been tested a little longer. Pretty soon we will be seeing all sorts of aftermarket stuff for our 6.0s. Then we can really build a screamin engine. |
Yes they are wanting people to test their product still. I was considering doing it, but I just blew my gaskest again! I know of a couple of people that are running them and love them. Get a hold of Bob over at Dieselsite and he will give you the lowdown on the HPOP.
-French |
Cracked head on the passenger side! The studs are good, just cracked the passenger side head. When I did the studs the last time, we took .008 off of each side and it must have made it just weak enough that the head let go.
-French |
Sorry to hear about that, how much work is involved? Do you pull the cab or the engine. Just gathering as much info as possible for that dreaded day!
![]() The 6.0 adrenaline is designed to flow more oil to support larger injectors. |
The guy at the machine shop said that taking .008 wouldn't be to much, so I trusted his answer. Oh well, just a chance to upgrade a little bit more.
-French |
I cant remember but I think .003 is the max that can be removed from a 6.0 head. Ford actually says replace dont machine them
![]() I though max spec was .008 ![]() -French |
