Torque specs - Ford Powerstroke Diesel Forum
Old 11-02-2009, 09:32 AM
Torque specs
I am planning to do a full EGR delete this weekend. Does anyone have the torque specs for all of the components that need to be taken off to get to the cooler (i.e intake bolts, turbo, pedistol, alternator, degass, etc)? Also, what size freeze plug do I need to weld into the uppipe, I imagine the uppipe is steel??
Thank You,
Jay
Old 11-02-2009, 10:05 AM
Feedback Score: 5 reviews
what delete kit did you get?
Old 11-02-2009, 11:28 AM
I am following a write up that I found on FTE. I plan to weld a 90* 3/4" NPT to 5/8 barb fitting in my intake. I will create a block off plate on the intake and weld a freeze plug in the uppipe. Other then that, I just need a heater hose and 2 hose clamps. Sounds easy on paper, but I am sure this will be a lot of work.
