Poor Fuel Mileage - Ford Powerstroke Diesel Forum
 13Likes
post #1 of 37 Old 11-27-2016, 04:18 PM Thread Starter
Quoted: 7 Post(s)
Poor Fuel Mileage
So I have a new to me 2006 F250 6.0 with 126k on it. Runs great, no known or obvious issues. I have yet to break 13.5 mpg with it. Took a 750 mile round trip this weekend with a 16' enclosed trailer with a weight of about 2100 lbs. and averaged 10.5-10.8 mpg the entire trip. To me this is terrible with that kind of load. Past diesels I've owned don't get that low until I'm in the 10k range. The truck is bone stock other than 285 tires and 4" exhaust. Any ideas on what to look for? This is the kind of mileage I'd expect from a V10, not a diesel.
JerryM is offline
The Following User Says Thank You to JerryM For This Useful Post:
Curti263 (02-19-2017)
post #2 of 37 Old 11-27-2016, 05:19 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Yea that's pretty bad I agree. I can't say why your that low for sure. But I will say a tune will improve it to a degree. A FICM tune like the Atlas40 along with a mild ecm tune will help. I am averaging low 17's mpg on my truck and 20-21 highway only.
Something's up, could be low on boost or a injector or two. Have you had truck looked at ?
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 37 Old 11-27-2016, 05:25 PM
ChrisSki's Avatar
Quoted: 137 Post(s)
I am stock, and I get marginally better than that.
IMO, Only thing you can really expect to do is tune both the FICM and PCM to get better mileage. With tuning you may get 20 to 25 MPG. Other than that, highway tires may get you a little more. There's other things, which I think would be a stretch, but if you can measure temps on the brakes to see if one is hung, than that may help.
My tires are 275s. If the weather is cold out and my oil doesn't warm up, I'll dip to around 13 MPG on a four hour highway drive, otherwise, I get around 15 MPG unloaded. I forget towing an enclosed trailer at around that weight, but that was around 10 MPG for me. I did not even notice the trailer behind me, but the MPG went way down.
2005 F250
172,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit
Bullet Proof EGR
ChrisSki is offline
post #4 of 37 Old 11-27-2016, 06:36 PM Thread Starter
Quoted: 7 Post(s)
I have an Atlas 40 tune on order, unfortunately I'm 4th in line so it could be 6-8 weeks before I recieve the remote programmer. Funny or not so funny thing is I just went to drive somewhere and now have a no start condition. ICP is only reading 250 while cranking. Guess I'll be dealing with that first.
JerryM is offline
post #5 of 37 Old 11-27-2016, 06:43 PM
djmaguire's Avatar
Quoted: 628 Post(s)
Garage
Yes to the no start being the bigger issue.
Regarding MPG... are you sure that you have a stock 3.73 rear end? If not, it's apples and oranges.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is online now
post #6 of 37 Old 11-27-2016, 06:51 PM Thread Starter
Quoted: 7 Post(s)
Yes, it has the stock 3.73 gears in it. It also reads 30psi on the stock boost gauge when wide open so I don't think it's related to low boost.
JerryM is offline
post #7 of 37 Old 11-27-2016, 10:05 PM
THIS IS HOW WE DO IT....
Quoted: 170 Post(s)
You might be better off sending you ficm to Ed at ficmrepair.com and you wont wait 6-8 weeks for your Atlas40. As long as you have a spare or another DD.
I have to say, your mileage is indeed crappy. When I moved to AK almost 5 years ago, I drove about 2600 miles, pulling about 10K. I averaged 16.9 miles hand calculated. That was with my '06.
I bought a '07 KR (after rolling my '06) and I have 275s BFG T/A Ko2 tires, 3.73 gears , banks CAI, synthetic oil only, Atlas 40 with 175/stock sticks.
I've gotten as high as 26 mpg going to Fairbanks and back last year. I normally average about 18 in town, depending on how hard I drive it and 20-22 on highway.
With that said, I'd look at a your brakes making sure nothing is dragging (look for discolored rotors, uneven caliper pad wear to start). How do you know for sure you have 3.73s? that will make a difference in your mpg.
Also have you replaced all the filters? run synthetic oil? Fuel additives (powerservice and/or Archoil)? Do you have a lift on the truck? or is is leveled?
Other thing to check is are you locked in 4wd (Auto v. Manual)?
mhatlen and 7.3 powerchoke like this.
Zach
07 F250 King Ranch FX4 CCSB, Dark Copper Metallic/Arizona Beige, Rotella T6+Archoil
6000K HIDs, Fog mod/High Idle, Tinted,
Banks CAI, Blue Spring, NUC/Amsoil Bypass Oil Filter
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
135,000 miles....
Air Force Veteran......Go Blue!
"Think of the most attractive person you know. Even that person, at some point, has had raging diarrhea"
Support Our Troops - Remember Our Veterans!
zsargent is online now
post #8 of 37 Old 11-28-2016, 03:54 AM
Quoted: 12 Post(s)
I am in the same boat with poor fuel economy. I am starting to blame a couple of injectors due to the rough cold start at only 35 degrees. I drove 4 hour round trip on thanksgiving to my parents and only got 12.1 unloaded on the freeway at 68mph. I am on 35s but did not think that mileage would be that low on the freeway. Right now I am get 9-10 in the city and 12-12.9 on freeway.
PbjPerformance is offline
post #9 of 37 Old 11-28-2016, 07:45 AM
G8orFord's Avatar
Quoted: 737 Post(s)
Garage
FYI, in case you didn't know, PHP currently has their FICM programmer on sale for $350. I'd imagine they would credit your loaner purchase towards the full programmer if you wanted to go that route.
Unplug the ICP and see if it starts.
Dexter
2004 F-250SD Lariat CCSB FX4 SRW
DashCommand on PLX Kiwi2 with iMFD
SCT X4 w/custom tunes (currently PHP 140x)
FICM from Ed
PHP FICM tuner (currently Atlas40)
KC Stage 1.5 Turbo
Blue Spring update
IPR Coolant Filter
Rotella ELC Coolant (CAT EC-1 rated)
BPD EGR Cooler
New (03/23/14) OEM Oil Cooler - (backflushed 05/10/15 @ ~40K & 07/03/16 @ ~70k)
G8orFord is offline
post #10 of 37 Old 11-28-2016, 07:49 AM
G8orFord's Avatar
Quoted: 737 Post(s)
Garage
Double post, and more on topic.
I've lost about 2 mpg over the last couple of years for some reason. For mixed driving. I averaged 17 mpg in 2014, 16mpg in 2015 and currently at 15 mpg for 2016. I'm fairly certain I have a small boost leak (thinking intercooler), but I haven't had enough time to really pinpoint it yet. Other than that, I'm not sure what might be the culprit.
Dexter
FICM from Ed
KC Stage 1.5 Turbo
Blue Spring update
IPR Coolant Filter
BPD EGR Cooler
G8orFord is offline
