What is the most common gear ratio for our trks. - Ford Powerstroke Diesel Forum
Old 10-22-2009, 02:01 PM
I checked mine last night & found it to be a 4.10. Is this the most common?
Old 10-22-2009, 02:02 PM
If you have 4.10 its prob a dually .
Old 10-22-2009, 02:04 PM
I have 4.10's but my truck also weights 12,000 every day.
Old 10-22-2009, 02:05 PM
Its not a dually. 2006 F250 Crew cab FX4.
Old 10-22-2009, 02:09 PM
I've never seen a single wheel with 4.10 from the factory
Old 10-22-2009, 02:20 PM
Maybe I'm wrong then. I may have been looking at the wrong chart. What's the best site to get a good code chart?
Old 10-22-2009, 02:22 PM
Tag on the gear housing will tell you without the code, will be stamped 4.10, 3.73, etc
Old 10-24-2009, 05:43 PM
The tag on mine is
v 423 F
73 10 5 3E21
So what is mine? I need to know as I may replace with one ton differential
Old 10-24-2009, 05:52 PM
Try this site.
Calulators from www.4Lo.com
Old 10-24-2009, 06:17 PM
Powerstroke Techie
Originally Posted by mike517 View Post
The tag on mine is
v 423 F
73 10 5 3E21
Your missing a couple of characters. In front of the 73 10 F 3E21 there is either one or 2 characters. there will be a 3 or a 3L depending on if it has limited slip or not. So you for sure have 3.73 ratios but you may or may not have limited slip. And you have a 10.5 inch ring gear. The tag should either read 3L73 10 5 3E21 or 3 73 10 5 3E21.
