I bought this truck about a year ago and wanted an oasis report done. Went to local dealer and was told that they couldn't do it because I didn't buy it from them.
Is this true? Can any one help, it's a 2005 F-350 vin is 1FTWW31P15EA23528
Thats crap. Just call another.
Yea any Ford dealership can get you one if they want to.
So they lied to me! Great
Probably just a lazy jerk working the desk. I called a dealership and told them I didnt buy it there. The woman's computer wasnt working so she actualy took my number and called me back after she called another dealership to get it. She went above and beyond. I think I might have flirted a little bit with her though...
Can anyone on here help me out with the report?
Nobody? I would really like to know this trucks history.
You can call any dealer. Just call one and be super nice to them, they will get it for you in 5 min!
Heres the oasis report...
VIN: 1FTWW31P15EA23528 BUILD DATE: 14-AUG-2004 WARR. START DATE: 04-OCT-2004 RO NUMBER: 1870394 Trx Code: E83 Labor Hrs: 0 DEALER PNA CODE: 48915 DEALER NAME: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2005 Doc #:15267804 Tech Comments: REQUESTING DEALER'S P/A CODE 02193 -------------------------------------------------------------------------------- VIN: 1FTWW31P15EA23528 BUILD DATE: 14-AUG-2004 WARR. START DATE: 04-OCT-2004 RO NUMBER: 1464722 Trx Code: E83 Labor Hrs: 0.6 DEALER PNA CODE: 02193 DEALER NAME: KOHMANN FORD, INC. Ph: 330-8687762 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2005 Doc #:00794301 Cust Comments: CUSTOMER SAYS RADIO/CD CUTS OUT, NO MATTER Tech Comments: IF VOLUME IS TURNED UP/DOWN, PLEASE CHECK. REMOVE RADIO FOR REPAIR AND REINSTALL -------------------------------------------------------------------------------- VIN: 1FTWW31P15EA23528 BUILD DATE: 14-AUG-2004 WARR. START DATE: 04-OCT-2004 RO NUMBER: 1722638 Trx Code: E84 Labor Hrs: 0.8 DEALER PNA CODE: 02193 DEALER NAME: KOHMANN FORD, INC. Ph: 330-8687762 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:25-AUG-2005 Doc #:00816601 Cust Comments: REPLACE NAME PLATES ON VEHICLE, LETTERING Tech Comments: IS PEELING OFF. CHECK AND REPLACE NAME PLATE ON TAILGATE AND RIGHT FRONT FENDER -------------------------------------------------------------------------------- VIN: 1FTWW31P15EA23528 BUILD DATE: 14-AUG-2004 WARR. START DATE: 04-OCT-2004 RO NUMBER: 2558430 Trx Code: S07 Labor Hrs: 0.3 DEALER PNA CODE: 06280 DEALER NAME: LOUDON MOTORS FORD, LLC Ph: 330-8687762 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:22-NOV-2005 Doc #:08568301 Cust Comments: CHECK OIL FILTER CAP LEAKING Tech Comments: REPLACE CAP AND CLEAN ENGINE -------------------------------------------------------------------------------- VIN: 1FTWW31P15EA23528 BUILD DATE: 14-AUG-2004 WARR. START DATE: 04-OCT-2004 RO NUMBER: 4319304 Trx Code: 59B01 Labor Hrs: 0.3 DEALER PNA CODE: 06280 DEALER NAME: LOUDON MOTORS FORD, LLC Ph: 330-8687762 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:12-APR-2006 Doc #:08681905 Cust Comments: ADD ON PER OASIS 59B01 POST TEST DRIVE Tech Comments: COMPLETED POST TEST DRIVE -------------------------------------------------------------------------------- VIN: 1FTWW31P15EA23528 BUILD DATE: 14-AUG-2004 WARR. START DATE: 04-OCT-2004 RO NUMBER: 4319303 Trx Code: 05E15 Labor Hrs: 1 DEALER PNA CODE: 06280 DEALER NAME: LOUDON MOTORS FORD, LLC Ph: 330-8687762 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:12-APR-2006 Doc #:08681904 Cust Comments: ADD ON PER OASIS 05E15 EBP SENSOR Tech Comments: REPLACED EBP SENSOR PER RECALL AND RECALIBRATED -------------------------------------------------------------------------------- VIN: 1FTWW31P15EA23528 BUILD DATE: 14-AUG-2004 WARR. START DATE: 04-OCT-2004 RO NUMBER: 4319305 Trx Code: 05B32 Labor Hrs: 0.2 DEALER PNA CODE: 06280 DEALER NAME: LOUDON MOTORS FORD, LLC Ph: 330-8687762 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:12-APR-2006 Doc #:08681906 Cust Comments: ADD ON PER OASIS 05B32 DEGAS BOTTLE RECALL Tech Comments: INSTALLED LABEL PER RECALL -------------------------------------------------------------------------------- VIN: 1FTWW31P15EA23528 BUILD DATE: 14-AUG-2004 WARR. START DATE: 04-OCT-2004 RO NUMBER: 7183150 Trx Code: S07 Labor Hrs: 5.8 DEALER PNA CODE: 20428 DEALER NAME: BORMAN MOTOR COMPANY Ph: 575-5254500 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:19-FEB-2007 Doc #:45825101 Cust Comments: D42 CUSTOMER STATES LACKS POWERS. IT LL IDEL BUT WONT REV UP. CHECK AND ADVISE Tech Comments: VERYFIED CONCERN,PERFORMED DIESEL DIAG 1 15.FOUND LOW FUEL PRSSURE ON L HEAD.PERFORMED INSPECTION,FOUND #4 AND #6 INJECTORS PUMPING BACK INTO FUEL SYSTEM,CAUSING A LACK OF POWER AND RO FOUND INJECTORS 2 AND 8 CAUSING MISSFIRE DUE TO LOW FUEL PRESSURE.REMOVED LEFT SIDE VALVE COVER,REMOVED AND INSTALLED NEW INJECTORS FOR 2 AND 8.RETESTED NORMAL -------------------------------------------------------------------------------- VIN: 1FTWW31P15EA23528 BUILD DATE: 14-AUG-2004 WARR. START DATE: 04-OCT-2004 RO NUMBER: 10493641 Trx Code: S07 Labor Hrs: 1.2 DEALER PNA CODE: 04544 DEALER NAME: RED MCCOMBS FORD Ph: 210-3494949 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2008 Doc #:62966701 Cust Comments: NO POWER ON ACCEL PASSING SPEEDS. BLOWS BLACK SMOKE. REPORT Tech Comments: BASIC 9F452 CC 42 NOT WORKING PROPERLY DIESEL DIAGNOSE FOUND STICKING EGR VALVE PERFORMED TEST FAILED REPLACED VALVE CLEARED DTC;S AND ROAD TEST SYSTEM PASS TSB 07 21 9 -------------------------------------------------------------------------------- VIN: 1FTWW31P15EA23528 BUILD DATE: 14-AUG-2004 WARR. START DATE: 04-OCT-2004 RO NUMBER: 10715339 Trx Code: S07 Labor Hrs: 2.2 DEALER PNA CODE: 04424 DEALER NAME: JENNINGS ANDERSON FORD Ph: 830-7553673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2009 Doc #:06600751 Cust Comments: ENG ON ACCELL LOOSES POWER AND STARTS BLOWING BLACK SMOKE ALSO CUST HIT A BUMP AND ENG STUMBLED BEFORE TAKING OFF Tech Comments: VERIFY CUSTOMER CONCERN NO POWER BLOWS BLACK SMOKE RETRIECED CODES KOEO PASS KOEO CMTCS P0470 P0472 P0528 PINOINT TEST 11 CIRCUIT TEST CK FOR VOLTAGE 4.8 VOLTS REPLACED THE EP SENSOR ALSO REPLACED THE EP SENOSR CONNECTOR PERFORMED A WIRE REPAIR CLEARED DTCS RETSED SYSTEM PASSED PEROFMED A EGR TEST PASS ALSO THE TUROB BOOST TEST PASS ROAD TESTED PID MONTIOR TURBO BOOST |
