fuel filter - Ford Powerstroke Diesel Forum
Old 10-22-2009, 01:18 AM
Would you say this fuel filters dirty?
bought my truck a few months ago and finally decided to change the fuel filters since i have no idea how old they were. got a steak knife and cut the filter in half and took a picture of it for the heck of it to see what yall would think. id say its pretty ditry!
Old 10-22-2009, 01:52 AM
Yea thats pretty dirty. But i have seen some alot worse than that. Wait till you get some water run through those. They look like they have alge on them. Good thinking on changing them though.
Old 10-22-2009, 01:53 AM
So how did you like the lower one? Was it fun?
Old 10-22-2009, 03:42 AM
That lower one can be a pain to get to. I got drenched with fuel when I did mine. By the way how many mile intervals should the fuel filter be changed.,.....5k
Old 10-22-2009, 01:42 PM
Manual says every 15,000 miles on both filters
Old 10-22-2009, 04:46 PM
How much diesel comes out of the lower filter when you open the drain plug? Wondering how big of a catch pan I need. Hoping to change mine on Sunday.
What size allen wrench is used for the plug. I've got a PDF of the fuel filter change procedure from Ford and in the steps it says 6mm, but in the list of required items at the end, it says 3/4" allen wrench? 6mm is close to 1/4", far from being 3/4"?
Old 10-22-2009, 05:29 PM
its a 6mm.
Old 10-22-2009, 11:13 PM
lol ya i got drenched. i did it at my parents house and didnt have the allen bit to unscrew the plug to drain the fuel. needless to say my mom wasnt verry happy when i used a towel to soak it up with
Old 10-23-2009, 07:40 AM
When I changed mine it was a few pints that came out it is way easier to pull the plug and drain it then taking the filter off to drain it.
Old 10-23-2009, 11:05 PM
Try, cutting to fit/size, something along the lines of a plastic detergent/bleach type bottle with an appropriate hanger for spillage of the lower fuel filter then you'll never have a problem or mess not to mention it is very easy to recyle the fuel into a reserve tank if desired..at least that is what I do..each to their own.
