Oasis Report? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-21-2009, 10:33 AM Thread Starter
Oasis Report?
Hi all! New to the forum and getting ready to purchase my first diesel. I would greatly appreciate having an oasis report run for the following VIN
1FTSW31P13EB47567
Thanks!
Sandman58 is offline
post #2 of 12 Old 10-21-2009, 10:47 AM
Go to the dealer. I had to show my vin and proof I owned it to get a copy, but he also told me I should have brought it in before I bought and he would give it to me. You might contact your dealer and see. It is free, and tell them you plan to use them for maintenance but want to know what kind of life the truck has had. I ended up sitting down and talking to one of their diesel techs and the maintenance manager for about 1/2 hour about what they see, what they suggest to do and not do, etc.
Good luck!
2005 F350 SRW, Crew cab short bed Lariat FX4. 85k. BPD HD oil cooler setup, BPD EGR cooler, Scanguage monitor.
2004 Excursion 6.0 - Lots of mods! SOLD!!!
Squid4life is offline
post #3 of 12 Old 10-21-2009, 10:58 AM Thread Starter
Thanks for the response. Unfortunately I won't be able to follow your recommendation. I am looking at buying the truck from a non-Ford dealership that is also out of state. I have no maintenance history, only the car-fax report. I was hoping to obtain an Oasis report to gain a little more info on the history of the truck.
post #4 of 12 Old 10-21-2009, 11:01 AM
Do you have a local ford dealership? It is nationwide, they can look it up.
post #5 of 12 Old 10-21-2009, 11:02 AM
troid123's Avatar
Send a message via AIM to troid123
Good luck!
He does not need to go to the dealer. Someone on here will be nice enough to do it for him...
2006 F250 CC Short Bed King Ranch 4x4 (109,000 miles)
4" Turbo Back w/ 6" Tip
SCT x3 w/ Custom Tunes From DJ's/Innovative
03 turbo
Eclipse Navigation/DVD/CD/MP3 w/ Rear Camera
Rear DVD/MP3/CD Entertainment System
Escort Passport SR7 Built In Radar Detection System
K & N Cold Air Intake w/ S&B Replacement Filter
Roll-N-Lock Retractable Bed Cover
Nitto Trail Grappler LT295/70R18
***SOLD 10/31/11***
New Truck:
2011 Ford F-150 Limited 6.2L Super Crew
troid123 is offline
post #6 of 12 Old 10-21-2009, 11:04 AM Thread Starter
Yes, couple of local dealerships. With your first post of needing proof of ownership and VIN, I didn't know if walking in and asking on a truck I want to buy from another dealership would be an option.
post #7 of 12 Old 10-21-2009, 03:28 PM
Ahh. Gotcha. Hopefully troid123 is right and someone will hook you up. I was able to go to the dealer, and "he said" that he would have given it to me before buying. Good luck either way. Hope yours comes out pretty clean.
post #8 of 12 Old 10-21-2009, 10:18 PM
Here's your oasis report on that truck bro good luck on the buy
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 2908151 Trx Code: 57B98 Labor Hrs: 0.5
DEALER PNA CODE: 09859 DEALER NAME: BAILEY TOLIVER FORD-MERCURY Ph: 940-8642611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2003 Doc #:02030104
Cust Comments: CUSTOMER STATES RECALL 57B98
Tech Comments: PERFORMED RECALL FREE OIL AND FILTER CHANGE
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003 RO NUMBER: 2908149 Trx Code: 03B06 Labor Hrs: 0.7
DEALER PNA CODE: 09859 DEALER NAME: BAILEY TOLIVER FORD-MERCURY Ph: 940-8642611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2003 Doc #:02030102
Cust Comments: CUST STATES RECALL 03B06
Tech Comments: PERFORMED RECALL 03B06
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 2908150 Trx Code: 03L12 Labor Hrs: 0.2
DEALER PNA CODE: 09859 DEALER NAME: BAILEY TOLIVER FORD-MERCURY Ph: 940-8642611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2003 Doc #:02030103
Cust Comments: CUST STATES RECALL 03L12
Tech Comments: PERFORMED RECALL 03L12
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 2908148 Trx Code: 03B05 Labor Hrs: 0.7
DEALER PNA CODE: 09859 DEALER NAME: BAILEY TOLIVER FORD-MERCURY Ph: 940-8642611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2003 Doc #:02030101
Cust Comments: CUST STATES RECALL 03B05
Tech Comments: PERFORMED RECALL 03B05
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 3078002 Trx Code: S07 Labor Hrs: 1.7
DEALER PNA CODE: 03566 DEALER NAME: GENE MESSER FORD Ph: 806-7932727 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-OCT-2003 Doc #:26054101
Cust Comments: DIESEL ENGINE LOW POWER CK NO POWER AT ACCELERATION D36
Tech Comments: 1 NO TURBO BOOST EXCESSIVE SLACK IN TURBOCHARGER SHAFT, REPLACED TURBOCHARGER.
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 3292954 Trx Code: E84 Labor Hrs: 2
DEALER PNA CODE: 03566 DEALER NAME: GENE MESSER FORD Ph: 806-7932727 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2003 Doc #:26144801
Cust Comments: DIESEL ENGINE FUEL LEAK CUSTOMER STATES VEHICLE HAS EXCESSIVE FUEL SMELL INSIDE
Tech Comments: EXHAUST SMELL DUE TO HOLE IN EXHAUST TUBE TO TURBO, REMOVED TURBO, REMOVED TURBOCHARGER ASSY, REPLACED EXHAUST TUBE ASSY INSTALLED TURBO, TEST DROVE.
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 3452239 Trx Code: E84 Labor Hrs: 1
DEALER PNA CODE: 09859 DEALER NAME: BAILEY TOLIVER FORD-MERCURY Ph: 940-8642611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2003 Doc #:02060501
Cust Comments: CUSTOMER STATES DRIVERS SIDE SEAT HAS SPLIT AT
Tech Comments: LEFT SEAT LOWER CUSHION COVER HAD SPLIT IN SEAMREPLACED DRIVERS LOWER SEAT COVER
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 3644260 Trx Code: S07 Labor Hrs: 2.1
DEALER PNA CODE: 07003 DEALER NAME: POLLARD FRIENDLY FORD COMPANY Ph: 806-7973441 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-DEC-2003 Doc #:07423651
Cust Comments: HARD TO START WHEN COLD. ROUGH IDLE. NO POWER
Tech Comments: CK FOR NO START AND RUNS ROUGH.PERFORMANCE DIAG, VISUAL INSPECTION OK, CHECK FUEL SYSTEM OK, CHECK OIL OK, PERF KOEO PASS, CONT CODES P0262, P02710280.PPT TEST P1. CHECKED AND REPLACE IDM. REFLASHED FICM, TCM. CLEARED AND RETESTED. ALL PASSED. TEST DROVE OK. TECH OUT MILEAGE ON REPAIR ORDER SHOWS 15758
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 4042579 Trx Code: E91 Labor Hrs: 11.5
DEALER PNA CODE: 07003 DEALER NAME: POLLARD FRIENDLY FORD COMPANY Ph: 806-7973441 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:22-DEC-2003 Doc #:07502551
Cust Comments: POOR ENG PERF WHEN COLD, TAKES TOO LONG TO WARM
Tech Comments: CK FOR NO START.NO START DIAG,PERF DIAG,VISU INSP,OK.CK FUEL SYST OK, CK OIL OK, KOEO PASS, CONT CODES P0272,P0275 AND P2769.PPT TEST P1.REOMVD BO 4 AND 5 INJECTORS.REINSTALLED VALVE COVERS. CHECKED AND REPLACE TURBO. CLEARED AND RETESTED ALL PASSED. MT TO R I VALVE COVERS AND REPLACE 4 AND 5 INJECTORS, ALSO REPLACE TURBO. NO LABOR OPS AVAIL. INJECTORS WERE NOT OPERATING PROPERLY, TURBO
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 7718767 Trx Code: E83 Labor Hrs: 0.9
DEALER PNA CODE: 03566 DEALER NAME: GENE MESSER FORD Ph: 806-7932727 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-SEP-2004 Doc #:29818201
Cust Comments: BUZZING COMING FROM DASH JUST BEHIND THE RADIO
Tech Comments: PERFORM MULTI FUNCTION SWITCH DIAGNOSIS. REPLACE MULTI FUNCTION SWITCH & FLASHER RELAY FLASHING SLOW.
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 13954202 Trx Code: 04S15 Labor Hrs: 0.4
DEALER PNA CODE: 03566 DEALER NAME: GENE MESSER FORD Ph: 806-7932727 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:05-JUN-2006 Doc #:36596803
Cust Comments: RECALL 04S15 ON NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK CONNECTION
Tech Comments: 1 PERFORMED RECALL 04S15 & REPLACED BATTERY GRAND BOLT.
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 13954201 Trx Code: 06E17 Labor Hrs: 0.7
DEALER PNA CODE: 03566 DEALER NAME: GENE MESSER FORD Ph: 806-7932727 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:05-JUN-2006 Doc #:36596804
Cust Comments: RECALL 06E17 ON CONTROL MODULE RECALIBRATION
Tech Comments: 1 PERFORMED RECALL 06E17 & REPROGRAMMED PCM, FICM, TCM W # 3U7A 12A650 FTG.
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 13954200 Trx Code: 59B01 Labor Hrs: 0.3
DEALER PNA CODE: 03566 DEALER NAME: GENE MESSER FORD Ph: 806-7932727 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:05-JUN-2006 Doc #:36596805
Cust Comments: CAMPAIGN 59B01 ONE TIME CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: 1 TEST DRIVE FOR CUSTOMER ASSURANCE
VIN: 1FTSW31P13EB47567 BUILD DATE: 09-DEC-2002 WARR. START DATE: 21-JAN-2003RO NUMBER: 13954203 Trx Code: S07 Labor Hrs: 5.4
DEALER PNA CODE: 03566 DEALER NAME: GENE MESSER FORD Ph: 806-7932727 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:05-JUN-2006 Doc #:36596802
Cust Comments: CUSTOMER STATES CK ENG LITE CAME ON FOR SEVERAL DAYS. IS OFF TODAY CK & REPORT
Tech Comments: KOEO, P0069,P0266,P0267,P0472,P1378,P2263,P2269. REPL HOT SD INTERCOOLER HOSE CONN. R&R L&R VALVE COVERS. REPL #2,3 INJS. #5 CYL BALANCE FAULT DUE TO POOR FICM CONTACT. REPL FICM HARNESS. FUEL PSI TEST. REPL FUEL PUMP7 MANIFOLD, EBP SENSOR
Socal-powerstroke is offline
post #9 of 12 Old 10-22-2009, 02:31 AM Thread Starter
Thank you, greatly appreciated. Not sure if this is good or bad news. Turbo has been replaced, several injectors replaced, FICM harness, fuel pump, EBP sensor, multifunction switch replaced, valve covers repaired. Several recalls, not sure what they are. Nothing on EGR or head bolt/gaskets. Last report in June 06. Looks like problems may have been fixed?
post #10 of 12 Old 10-22-2009, 07:24 AM
Seems like a pretty good report, not a whole lot of major stuff. Recalls are many times small fixes. Last report is probably when the warranty runs out. Correct me if I am wrong, but Oasis is just showing what was doen under warranty. If warranty runs out and you have work done, it is out of pocket and not on the Oasis.
Good luck with the truck. Nothing on that report scares me.
