New Tow Rig - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-20-2009, 04:52 PM Thread Starter
Daddys_Limousine99's Avatar
New Tow Rig
Hey guys,
I just added a new tow rig to the stable. It's a 2006 F-350 4x4 King Ranch 6.0 with 81K on the ticker. I took it in to our local dealership to have it checked out and it came back pretty good. They did find an oil leak...should be fixed tomorrow. I have a couple of questions about this new truck:
1. The Speedometer intermittently starts out at 20ish and drives up from there (obviously inaccurate)...sometimes it starts out higher, like 50, and drives up as I accelerate, any ideas...really just an annoyance.
2. How do you guys like the Tow Command? Does it work well? I have a 12K Fifth Wheel that I tow with the 99 (sexy lookin green truck in the pictures) and a P3 brake controller.
Thanks!
nate
ID:	10890   Click image for larger version
ID:	10891   Click image for larger version
ID:	10892   Click image for larger version
Daddy's Limousine: 2006 F-350 King Ranch 4x4, Auto, CC, LB, Ranch Hand bumpers/headache rack
Daddys_Limousine99 is offline
post #2 of 7 Old 10-20-2009, 05:24 PM
work&play's Avatar
Quoted: 2 Post(s)
I realy like my tow command set up.
My GCVW is some times 22-23,000 lbs and it helps a lot
2007 6.0 PSD,F350 4X4 Lariat,CC, DRW,9' Knapheide body, stainless steel lader rack, SCT with custom tunes, ARP's, EGR delete, ITP RR, Airdog II 130/75, Garrett Powermax, Banks turbo back, Firestone air bags, Autometer gauges
work&play is offline
post #3 of 7 Old 10-20-2009, 05:35 PM
southern7.3's Avatar
Nice rig....one day I WILL have a KR
Sam
2005 F350 King Ranch CC DRW Insight Leveled 4" MBRP Straight Pipe Tinted
'99 F250 - Sold
'99 Cummins - Sold
southern7.3 is offline
post #4 of 7 Old 10-20-2009, 05:43 PM
tabraha's Avatar
First of all nice rig (s)!!! I'm pleased with how well tow command works. I pull a 37' fiver that comes in around 13k-14k (grossing 21-22k) dependent upon how much the women folk take. Tow Command does a great job with it.
Tad Abraham
2005 F-350 DRW 6.0PSD Longbox
CrewCab 4.10's and a Limited Slip - Nicknamed "TINY"
B&W 5'er/Turnover Ball on top, better MPG than my half-ton
155,000+ on the clock
SCT X3, DJ's Diesel Performace Looney 160,Tow 50 and Econ 40 Tunes
Autometer triple pillar with Trans, Boost and Pyro Ultralite II's
4" Farmboys exhaust with cat delete
ARP studs installed and EGR Valve welded by Scott @ Trucks Unlimited
tabraha is offline
post #5 of 7 Old 10-20-2009, 05:49 PM
Tow command is the cats ***, it works so much better than the old style controllers, no herky jerky trailer brake activation and its super easy to set. I pull a 30' gooseneck every day that is constantly loaded to 13 or 14k.
05 F350 FX4 Crew, Auto, 6.0, ARP Studs, EGR delete, and Magnaflow Duals, Cage leveling kit, 33x12.5x18 Toyo Open Country MT's.
Blue05 is offline
post #6 of 7 Old 10-21-2009, 04:44 PM Thread Starter
Well, it looks like tow command might be good then...I'll have to wait until next week to try it out. What gain are yall running with your setups?
So, the Ford Dealer says the speedometer is the cluster. Apparently they hooked up the computer and got the speedo to do a full sweep, but said that it is probably going bad. The darn thing worked the whole way home, so we'll see. They want $285 plus 2 hrs of labor to change it out. Apparently it has to be programmed to the truck, so it's not something that I can order and change out myself...bummer
post #7 of 7 Old 10-22-2009, 05:06 AM
tabraha's Avatar
I usually start with 5.0 and have never needed to run over 8.0
Tad Abraham
tabraha is offline
