Turn Signals
Quick question, My boss has a 07 with the 6.0 but I dont think that matters in this situation. Her laft side turn signals are not functioning propperly. Rplaced the front bulb, did not fix the problem, I checked all the fuses and all were good. Rear lamp pulses extremely fast which I would assume means there is a short? Wondering if there was a quick fix. Thanks for the help.
So no one has a clue? Just a fluke?
It's late so maybe you can get replies tomorrow.
As for the problem, I'm not sure. As for your lady boss that drives an 07 6.0... Is she hot? Sounds like a keeper
morning bump for you. No moisture in the lens housings and all the bulbs are in tight? I'd swap bulbs left side to right side and see if the issue moves with the bulbs, front and back. That would either eliminate the bulbs or eliminate the wiring/relays.
