Valvoline premium blue 5w40 synthetic - Page 6 - Ford Powerstroke Diesel Forum
post #51 of 56 Old 11-08-2009, 02:56 PM
Originally Posted by dieseldan2005 View Post
So whats the difference between mobil 1 "turbo diesel truck" oil and mobil delvac 1?
The formula is the same.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is online now
post #52 of 56 Old 11-08-2009, 05:12 PM
Snake's Avatar
Quoted: 46 Post(s)
Originally Posted by HeavyAssault View Post
Don't count out Mobil 1 which I feel performs about the same as Valvoline for my motor. Glad to hear you like your new oil keep us posted as the miles rack up on this change.
Will do. My plan is to drive this for 5k and run a Blackstone report. Last time I ran one, I was on Rotella for about the same mileage and it wasn't that favorable. So I'm real curious to see what they say about the Extreme Blue.
--Snake
Snake is offline
post #53 of 56 Old 11-08-2009, 05:13 PM
Goose350's Avatar
So there wont be any problems switching to synthetic with 220k on the truck?
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #54 of 56 Old 11-09-2009, 09:13 AM
Baddestt's Avatar
Quoted: 8 Post(s)
No there shouldn't be, as long as you don't have any pre-existing oil leaks. You will definately notice a difference with the Mobil 1 TDT or Valvoline Premium Extreme...both are 5w40 syn oils and perform about the same...Mobil 1 tends to be a lil more expensive...
'07 F-250 PSD 4x4
5" exhaust, zoodad, blue spring, Airaid intake, 6.4 starter, 2.5 f/coils, adj Trac bar, 2" r/add-a-leafs, egr delete, snow plow fan clutch, csf 6028 intercoolerr, DC 185 alt, Bilstein 5100, Barder '03 turbo rebuild w/RR billet wheel, SCT SF3 tuner, F-Detroit Truetrac, R-Detroit Locker, 4:10 gears, hawk LTS, LT315/70r17 Duratracs, Amsoil Gear lube, Delo 400 LE 5w30 diesel, Delo ELC, archoil, bpd ficm, BPD oil cooler, dynatrac pro steer ball joints, arp studs, oem gaskets, HD water pump, stc, plugs, stand pipes, 6.4 banjo bolts,
Baddestt is offline
post #55 of 56 Old 11-09-2009, 09:19 AM
I've never found the PBE as cheap as the TDT. TDT is around $22/gallon, NAPA is the only source for PBE at $25-28/gallon.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #56 of 56 Old 11-09-2009, 10:37 AM
the pbe was on sale a month or so ago for $17.99 at napa you just have to find a real napa store not one of there franchise
mx730md is offline
