gauge install ??
Just got my fuel pressure gauge and my coolant temp gauge, where is the best place to put these sensors to get the most accurate readings possible. I have the RR kit installed for the fuel system?? .... thanks
What RR kit did you use?
Fuel Pressure would be here
Install Pictures And water/coolant temp should be here 3-Gauge Install Pictures Hope that helps |
For the fuel psi there is a test port on the side of the fuel bowl and you should an adapter like the one from ITP
6.0L Fuel Pressure Adapter Then for coolant temp there is a plug on the driver side near the rear of the block that you can get to from under the truck. |
