Keeping my Injectors Happy - Ford Powerstroke Diesel Forum
Old 10-19-2009, 01:34 PM
NOT a Democrat
What fuel addive are you guys using? Is the 2 stroke oil really a good way to go?
Thanks!
Old 10-19-2009, 02:40 PM
stanadyne, two stroke oil, diesel kleen. i dunno there have been alot of recent thread discussing this.
Old 10-19-2009, 02:47 PM
I use diesel kleen.
Old 10-19-2009, 03:04 PM
I use Stanadyne.
Old 10-19-2009, 03:12 PM
lol see case in point several different options
Old 10-19-2009, 03:36 PM
The BEST thing for your injectors is to keep the fuel pressure above 45 psig.
Old 10-19-2009, 03:37 PM
^ dont they run at like a couple thousand? or is that oil injecters?
Old 10-19-2009, 03:44 PM
Two suggestions for happy injectors. First the cheapest is TRY a gallon of 2-stroke. Get the TCW-3 rated version from Wally World at $12 a gallon. Use at 1oz per gallon of fuel.
Second suggestion is run an AirDog. It will get the entrapped air out the fuel, remove the water and filter the fuel. I noticed a difference in noise 30 seconds after I started my motor when I finished my install.
Old 10-19-2009, 03:52 PM
i know it helped my cummins (2 stroke) unsure about the powerstroke!
I use Lucas Injector cleaner, just what I believe in.
