How does my truck look? - Ford Powerstroke Diesel Forum
Old 10-18-2009, 10:07 AM
VIN: 1FTWW33P05EA54881 BUILT DATE:08-SEP-2004 WARR. START DATE27-SEP-2004 RO NUMBER: 4384093 Trx Code: E84 Labor Hrs: 26.5
DEALER PNA CODE: 01534 DEALER NAME: WILLOWBROOK FORD, INC. Ph: 630-9865000 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2006 Doc #:06487351
Cust Comments: CHECK OIL LEAK
Tech Comments: WPI R&I TRANS R&R REAR MAIN SEAL AND RE SEAL EACH BOLT FOR CRANK REAR ADAPTER RD TEST INSPECT AGAIN LEAKING DIFFERENT AREA R&I ENGINE AND INSPECT RESEAL BED PLATE TO BLOCK R&R COVER GASKETS ABNORMAL TIME TO RESEAL BOLTS AND TO R&I SNOW PLOW AND CONTROLS
VIN: 1FTWW33P05EA54881 BUILD DATE: 08-SEP-2004WARR. START DATE: 27-SEP-2004 RO NUMBER: 4369539 Trx Code: 05B32 Labor Hrs: 0.2
DEALER PNA CODE: 01534 DEALER NAME: WILLOWBROOK FORD, INC. Ph: 630-9865000 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2006 Doc #:06487354
Cust Comments: PERFORM RECALL 05B32 DE GAS BOTTLE
Tech Comments: WPI PERFORM RECALL X
VIN: 1FTWW33P05EA54881 BUILD DATE: 08-SEP-2004WARR. START DATE: 27-SEP-2004 RO NUMBER: 4369538 Trx Code: 59B01 Labor Hrs: 0.3
DEALER PNA CODE: 01534 DEALER NAME: WILLOWBROOK FORD, INC. Ph: 630-9865000 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2006 Doc #:06487353
Cust Comments: PERFORM RECALL 59B01 TEST DRIVE
VIN: 1FTWW33P05EA54881 BUILD DATE: 08-SEP-2004WARR. START DATE 27-SEP-2004 RO NUMBER: 4369537 Trx Code: 05E15 Labor Hrs: 1
DEALER PNA CODE: 01534 DEALER NAME: WILLOWBROOK FORD, INC. Ph: 630-9865000 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2006 Doc #:06487352
Cust Comments: PERFORM RECALL 05E15 EPS SENSOR
VIN: 1FTWW33P05EA54881 BUILD DATE: 08-SEP-2004WARR. START DATE: 27-SEP-2004 RO NUMBER: 8458402 Trx Code: S07 Labor Hrs: 5.3
DEALER PNA CODE: 03177 DEALER NAME: BRIGHTON FORD, INC. Ph: 303-6593434 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2007 Doc #:074652B
Cust Comments: CUSTOMER STATES THE TRUCK SEEMS TO BE RUNNING HOT ALSO
Tech Comments: 28802 TEST DROVE FOUND TEMP GAUGE AT NORMAL OPERATING RANGE PERFORMED COOLING SYS PRESSURE TEST FOUND LEAKING FROM REAR OF MOTOR FOUND COUPLER AT EGR COOLER LEAKING REMOVED INTAKE MANIFOLD INSTALLED NEW COUPLER REASSEMBLED AND RETEST FOUND NO LEAKS AT T THIS TIME
VIN: 1FTWW33P05EA54881 BUILD DATE: 08-SEP-2004WARR. START DATE: 27-SEP-2004 RO NUMBER: 8458401 Trx Code: S07 Labor Hrs: 3.7
DEALER PNA CODE: 03177 DEALER NAME: BRIGHTON FORD, INC. Ph: 303-6593434 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2007 Doc #:074652A
Cust Comments: DIAG THE CUSTOMER STATES THE TURBO IS LOOSING BOOST AND BOUNCING BACK AND FOURTH 15 20
Tech Comments: 28802 VERIFIED CONCERN PERFORMED KOEO SELF TESTS FOUND P0299 IN MEM FOLLOWED PINPOINT TESTS SAID FAULTY TURBO PERFORMED BOOST PRESSURE TEST FOUND BOOST LOW CHECKED INTAKE FOR LEAKS NONE FOUND PERFORMED TSB 071601 FOUND TURBO COULD BE CLEANED FOUND VGT SOLENOID HAD DEBRIS ON END OF IT CLEANED TURBO AND INSTALLED NEW VGT SOLENOID REASSEMBLED AND RETEST FOUND NO CONCERN AT THIS
VIN: 1FTWW33P05EA54881 BUILD DATE: 08-SEP-2004WARR. START DATE: 27-SEP-2004 RO NUMBER: 9576713 Trx Code: S07 Labor Hrs: 4.9
DEALER PNA CODE: 01534 DEALER NAME: WILLOWBROOK FORD, INC. Ph: 630-9865000 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2008 Doc #:02334702
Cust Comments: SMOKE THROUGH EXHAUST
Tech Comments: PERFORMANCE DIAGNOSTIC SERIES; DTC P0266; REPLACE 2 INJECTOR
VIN: 1FTWW33P05EA54881 BUILD DATE: 08-SEP-2004WARR. START DATE: 27-SEP-2004 RO NUMBER: 10687037 Trx Code: S07 Labor Hrs: 3.3
DEALER PNA CODE: 01534 DEALER NAME: WILLOWBROOK FORD, INC. Ph: 630-9865000 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2009 Doc #:03834401
Cust Comments: ENGINE IS CHUGGING AND WHITE SMOKE THROUGH THE EXHAUST
Tech Comments: DTC: P0272 RUN DIAGNOSTIC TESTS PER LISTED, REPLACE 4 FUEL INJECTOR. DDDR3 DIFFERANT PART THAN RO 6023347
Forward Message
Old 10-18-2009, 10:21 AM
Its deff had some work done to it. To bad none of it was head studs or EGR delete.
Old 10-18-2009, 10:23 AM
I'm new to diesels, could you maybe explain to me what all this means.
Old 10-18-2009, 10:56 AM
Old 10-18-2009, 12:46 PM
Looks like they put a new rear main seal in and it did not fix the problem. So then they yanked the motor to reseal the bedplate. Looks like that fixed it. They also state that the abnormal shop time is due to removing anf reinstalling a snow plow.
Thats what i get out of it.
Old 10-18-2009, 12:52 PM
So what does R&R and R&I mean?
Old 10-18-2009, 12:56 PM
remove and repair, and remove and inspect I believe
Old 10-18-2009, 12:57 PM
R&R= Remove and replace or remove and repair.
R&I= Remove and install
Old 10-18-2009, 01:05 PM
Ok, thanks. Would you guys say the problems the truck has had aren't too bad? Let's put it this way, would you buy it if it was the truck you were looking for? I already did so too late.
