removeal question
Can anyone help give me any tricks to removing the turbo? we have a super stuck bolt that doesn't want to seem to get loose. Oviously it's the back one and we already don't have much room? Any help would be great. Thank
First thing to do is to soak it in PBblaster or equivalent! The best wrench to get the turbo bolts off with is a 10mm flex head gear wrench--IMHO
When I took mine off I used a 6" extension to get above turbo on a 3/8" drive ratchet, worked great.
I agree with both the above.
SOAK it in PB-Blaster, DEEP Creep or something stronger than WD-40. The back one I found easier with an extension or combination of and a 3/8 ratchet. I shoved my work light in there so I could see through the pedestal it may also help to pull back the wire harness carrier with a string tied to your wiper. the ratchet will allow for a cheater too. |
I use a 3/8 stubby ratchet and a 6" extention...it worked well for me.
thanks fellas. we've soaked it in PB, used ratchets and extensions and everything. the dang thing is so rusted it's not budging.. we've been at this for a while. I'm about to light it on fire and call it a night! haha
you absolutely have to take the turbo/pedestal off in order to do an egr delete right?
yes sir.
Here are some good instructions for cleaning it...Diesel Technician Society
