Head stud install pics. - Ford Powerstroke Diesel Forum
post #1 of 19 Old 10-17-2009, 08:59 AM Thread Starter
T.R.P.'s Avatar
Talking Head stud install pics.
more to come
If you don't drink Dos XX's, you need to start today.
2007 F-250 Lariat FX4
SCT w/ Matt's SRL
37" Toyos on 18's
75,000 HARD miles and absolutely no problems. What's the deal Bill?
T.R.P. is offline
post #2 of 19 Old 10-17-2009, 09:09 AM Thread Starter
T.R.P.'s Avatar
SCT w/ Matt's SRL
37" Toyos on 18's
T.R.P. is offline
post #3 of 19 Old 10-17-2009, 09:13 AM Thread Starter
T.R.P.'s Avatar
SCT w/ Matt's SRL
37" Toyos on 18's
T.R.P. is offline
post #4 of 19 Old 10-17-2009, 09:25 AM
Hopefully Ill be doing this over Christmas Break .
03-blue-Powerstroke is offline
post #5 of 19 Old 10-17-2009, 09:34 AM
Raging Lunatic
choctaw's Avatar
Did you run a tuner prior to this?
Halito...Sa hohchifo ut Mike
On EARTH as it is in TEXAS
ΜΟΛΩΝ ΛΑΒΕ
"Fast Service Guaranteed...No Matter How Long It Takes"
choctaw is offline
post #6 of 19 Old 10-17-2009, 09:39 AM Thread Starter
T.R.P.'s Avatar
Yup. I'm going to run the truck stock for a while though. I have a power pup, triple dog, and superchip sitting her for it but will wait til I can buy the SCT.
SCT w/ Matt's SRL
37" Toyos on 18's
T.R.P. is offline
post #7 of 19 Old 10-17-2009, 09:44 AM
man is that all rust on your frame? i thought mine was bad and mine is a 04 with 80,000 miles
so are they doing studs under warrenty? if so your lucky
mx730md is offline
post #8 of 19 Old 10-17-2009, 10:23 AM
Tacomarunner's Avatar
Burn pattern on pistons?
O7 F-5504dr 4wd cab and chasis w/ 12' Scelzi service body 6spd manual trans. 200" WB 17,950 GWWR 4.88 gears
Overhead gauges w/ EGT and Boost. FCDP EGR Delete. AEM Workhorse CAI. Down pipe only, no cat or muff.
Tacomarunner is offline
post #9 of 19 Old 10-17-2009, 10:40 AM
The deck surface looks pretty rough. have them pull the plugs on the block to drain all the coolant out, then install a coolant bypass filter. better loose that stock egr cooler too. Ford Power Stroke 6.0L Parts Upgrades from BulletProofDiesel.com
Robsr is offline
post #10 of 19 Old 10-17-2009, 10:58 AM
arcticatman's Avatar
i was thinking the same with that frame. get that sprayed.
1997 350 7.3 dump truck/Work Truck
2008 350 Reg Cab
H an S 300 tune
Flo pro egr delete with elbow
Flo pro 5 inch turbo back
s an b intake
Cat ELC
Ready Lift 3.5 sst kit
20inch Platinum wheels
Much more to come!
arcticatman is offline
