Need fuel pressure gauge help - Ford Powerstroke Diesel Forum
Old 10-17-2009, 07:41 AM
Ok so where is the best place to hook up a fuel pressure gauge and where can I order the parts to get it hooked up. I think my fuel pump is going out again and want to hook up a gauge to see. I cant believe it would be going out again it only has 5 months on it and change fuel filters about once a month.
Old 10-17-2009, 08:05 AM
This should help you out
Install Pictures
Old 10-17-2009, 08:13 AM
Ya that helps a lot. Do you no after I pull that plug out if its pipe threads or speciall threads and need a adapter.
Old 10-17-2009, 08:25 AM
You need the adapter listed on that page, I believe if you buy the stainless fuel line from them you get the fitting. Also you might want to look into running an isolator so you don't have to run fuel into your cab.
Old 10-17-2009, 10:41 AM
i was going to get an electric one so all you need is that adapter and hook the sending unit up to that.
