OASIS REPORT? - Ford Powerstroke Diesel Forum
Old 10-16-2009, 12:36 PM
OASIS REPORT?
Can I please get an oasis on '06 F350 Vin # 1FTWW31P56EB77340.
Thanks!
Old 10-17-2009, 01:19 PM
looked up your oasis for you and dont seem to be to bad... heres what i found.
VIN: 1FTWW31P56EB77340 DATE: 02-DEC-2005 18-JAN-2006 CLAIM KEY: 2223547 Trx Code: S07 Labor Hrs: 6.7
DEALER PNA CODE: 09673 DEALER NAME: RELIANCE FORD PH:281-4711642 ST:TX Ctry Cd: USA Reg Cd: NA Repr Date:23-AUG-2006 Doc #:183908A
Cust Comments: CUSTOMERS STATES CK FOR ENGINE DIES WHILE STOPPING AND NO RESTART
Tech Comments: NO START DIAG FOUND VEH HAS HI PRESSURE OIL CONCERN REPLACED HI PRESSURE OIL PUMP RETEST CKS OK
VIN: 1FTWW31P56EB77340 DATE: 02-DEC-2005 18-JAN-2006 CLAIM KEY: 2223547 Trx Code: S07 Labor Hrs: 3.2
DEALER PNA CODE: 06516 DEALER NAME: NATCHITOCHES FORD LINCOLN-MERCURY PH: 318-3523677 ST:LA Ctry Cd: USA Reg Cd: NA Repr Date:04-APR-2007 Doc #:06869501
Cust Comments: CS THAT CHECK ENGINE IS ON, AND MISFIRE ALSO
Tech Comments: FOUND RUNS VERY ROUGH. SCAN FOR CODES. P0303 FOUND INJECTORS ON RIGHT BANK BAD DUE TO LOW FUEL PRESSURE REPLACE INJECTORS ON THE RIGHT BANK.
Old 10-17-2009, 07:15 PM
Thanks, Socal. I really appreciate it. This truck now has 205,000 miles on it. Its in Indiana for sale for 17,000. Oasis is great. Carfax came back clean too.
I'm still concerned about it though because it has an '03 and earlier style front end on it? Current owner said it was that way when he bought it and it doesn't show any other signs of being wrecked.
Old 10-17-2009, 08:54 PM
yeah ive seen trucks with that style front end, seems like they might be running a 7.3L and when you pop the hood you find it equiped with a 6.0L shocking huh. well the truck seems to be in great shape good luck...
