My oasis report
Ok finally got it!!...It would seem my 05 has been in for warranty work 3 times..
12/27/05--reprogramed pcm tcm ficm to latest calibration 1/3/06--replaced emblem #5c3z 2/1/06--replaced ep sensor and recalibrate 2/1/06--road tested per program 59b01 2/1/06--vehicle has program 05b32 install label degas bottle,remove fuid Thats all that showed up..This good,bad? ,,,nothing from 06 to present |
Thats looks GREAT compared to mine. My trucks oasis was two pages long but I still bought it and haven't had a single problem yet, I was just hoping they fixed them all before I bought it.
Looks good, here is what I found after purchace. If I would have know don't think it would be in my driveway.
1- April 05 -Replace leaking thread dambage pulg and gasket, clean oil blow buy off coller pipe and retighten loose clamp. (don't have a clue what it was) 2- June 06 - PSD code 402, 406, 269, 284 found replae injectors and test again code 269 and 284 gone but 402 and 406 still active remove EGR vavle and inspect, internal gallery contamined by carchoal reme int manfl and lcean intall new EGR valve test ok 3- June 06 - Preforme recall work charge air cooler duct replace L 4- June 06 - Preforme recall work E series intall ICP connector kit 5- June 06 - Preforme recall work recal exhaust prssure sensor replacment, on board diagonstic stystem and engine contr ol modules recalibration 6- July 06 - PSD code 2284 found, remove ICP and insnpect. ICP damage replace and inspect IPR some debris found at IPR and screen show damabe replace IPR and test ok 7- Nov 06 - Test drove noticed vehicle overheating pressure tested cooling system wound not hold above 10 psi R&R EGR valve round coolant in valve intake determined EGR cooler to be leaking and EGR cooler caused to fail by oil cooler R&R alternator R&R fan shourd R&R intake mainifold R&R EGR cooler R&R oil cooler and...... (report just ended) 8- Dec 06 - Test dorve check engine light on while driving source of noise to be Y pipe conductd diesel performance check found p0404 conduted pinpoint test ka let to turbo replacement. |
Wow sparkless thats alot but it looks like its been good since 06 so I guess thats a good thing!..My warranty runs out in march of 2010 so i'm thinking about that extended warranty plan I think 5yr/200,000mi...
Too bad that only shows things under warenty. Time on clock when I got it was 107,000. Now I've got little over 132,000.
Things have been ok since I got it. High pressure oil pump died, alt gave out shortly after a belt and tensioner change, and the big one 3 injectors last year. Just happen to be all on the same side to I did all 4 just to be sure. Knock on wood.... plan on a coplete EGR system delete and studs when $$ is in hand. |
seems like the egr delete is the way to..I guess thats where most of the problems start?
Yes an EGR complete delete system, or a block of system can fix several problems but so can the right foot.
Have fun with your rig. When you start to mod your truck make sure you have some supporting mods to go with. Last edited by POWERED SPARKLESS; 10-17-2009 at 12:49 PM. |
May be a stupid question, but where/how/how much for the Oasis? Is it an online deal or from a dealer?
EDIT>>> Nevermind, just talked to the local dealership. They do it free, just have to show registration and ID. Last edited by Squid4life; 10-16-2009 at 04:12 PM. |
Lol! yeah oasis is free, i work for a ford dealer and have access to the webpage at home if you want i can get you that in a matter of 2 min! I dont need your registration information only your vin number if your comfortable giving that type of information out!
