bad turbo???? - Ford Powerstroke Diesel Forum
Old 10-16-2009, 07:45 AM
bad turbo????
well the last month or two id say, when i start my truck in the morning it takes a about 15-20 seconds before i hear the turbo start to spool. now about 2-3 seconds after initial start i get oil pressure like normal and as soon as that used to happen i can hear the turbo come on. now after 20 seconds like i said there is a lil screatching sound then here comes the "jet" note from the exhaust. i change my oil 2500-3500 miles and use rotella for the most part and wix filter. i did use delo this past oil change but this symptom happend before i changed oil anyway. any thoughts???
Old 10-16-2009, 07:52 AM
wriott
Guest
Posts: n/a
pull the intake tube and see if you can spin the wheel without any resistance
Old 10-16-2009, 08:06 AM
it spins freely and once it comes on all is well. builds boost fine and runs fine. idk
Old 10-16-2009, 08:09 AM
wriott
Guest
Posts: n/a
any play in the shaft... up, down, in, out???
Old 10-16-2009, 08:35 AM
very very very minimal. guess i could always find a 03 turbo or just get this one rebuilt.
Old 10-16-2009, 08:57 AM
wriott
Guest
Posts: n/a
when you move it around does it hit the sides at all...
Old 10-16-2009, 10:43 AM
no sir. im lost
Old 10-16-2009, 10:49 AM
just an idea. could it need to be cleaned? sticky vanes?
Old 10-16-2009, 11:09 AM
wriott
Guest
Posts: n/a
but what would cause the squeel??? are you sure its comming from the turbo...
Old 10-16-2009, 12:05 PM
ya. its engine idle then squeal for about as long as it takes to snap your fingers then the nice roar of jet exhaust. but only first start in morning. through out the day nothing. just in the a.m.
