oh boy! trashed lpop
Well its been awhile since ive been on here but ive got a question for you guys. I had a 2003 6.0l come in the shop yesterday it had very low icp pressure and voltage. The oil pressure gauge on the dash came up and it filled the oil filter bowl, but slowly. I hooked my mechanicaloil pressure gauge up and found low base oil pressure. I then pulled the ipr off, found trash on the screen. I then proceeded to remove the low pressure oil pump, found that to be trashed as well. Then i removed the passenger side valve cover and turned the motor over by hand the #1 cyl exhaust valves do not move. I did not remove the driver side valve cover yet... So im assuming the lifter failed spreading metal parts through the whole system destroying the lpop, hpop, ipr, injectors, and who knows what else. So what do i recommend? A new engine? Any advise would be greatly appreciated!! I have not experienced this problem before, so any advise would be great!! Thanks in advance!!! Also has anybody found a cause for the lifter failure?
Ok upon our recommendations the customer is having us install a used engine with no warranty. Shop cost on a reman from ford was 11,000 dollars so clearly the used engine was a better route. I got the cab off this morning then got busy with other stuff while waiting for an engine. So monday i will tear down the junk engine and snap a few pictures of the destruction.
Ouch.... $11k... Wow. Interested in the carnage pics. So if a guy could pick up a 2003 6.0 for about a grand, that would be a good deal to hold on to?
You can check the voltage somewhere to see icp pressure/voltage? Curious as I am having a no start/ low idle/ dying issue and was curious if icp could be part of it. I may have to pick your brain!
Thats alot of damage! $11000
Yes you can read icp pressure and voltage with a scan tool like the ford ids which is what i use. There are much cheaper scan tools that can do the trick i think autoenginuity is a pretty good one, but i have no experience with it. Or you can check icp voltage with a multimeter right at the icp sensor connector on the dark blue/ light green wire and the gray/red wire. Should be .8v to make it start. ICP very well could be a part of your problem. You can check voltages without the scan tool but you will need a good scan tool that can read pids to do more diagnostics. Feel free to ask any questions i will do my best to answer them!!!! |
I found one that had lost the needles in the lifter roller. customer said it had a misfire for some time. came in as a no start. engine oil pump was destroyed from matel chips. oddly they looked to large to fit through the pick up screen. wound up long blocking it, 8200 bucks.
Im not sure how accurate the voltmeter would be but i know that with KOEO icp voltage should be at .9 and pressure at 0psi anything above 30psi you have a bias icp, ipr should be 14.8%, KOER icp pressure should be grater than 500psi since thats the minimum psi required to fire injectors, monitor icp pressure when you incounter the crank no start if icp pressure is lower than 500psi you may have a high pressure oil leak and would suspect stand pipe o rings or stc fitting at fault..
Will have to see what I can do with the multimeter. Have an SCT but it says no codes present. Will it show the same as another handheld scanner? |
