Y'all reckon my 6.0 got screwed up? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-14-2009, 06:43 AM Thread Starter
tabraha's Avatar
Here's the background (also see sig for specs):
Intermittent turbo overboosting, lack of power when it wasn't boosting properly. I told them it had been doing this for a couple weeks but I just watched my gauges and didn't lay in the throttle after seeing it boost over 35psi. Been able to drive it with light loads as long as I used the gauges. I figured sticky vanes or a crapped out VGT actuator. Didn't have time for DIY so took it in to the dealer get it looked at. (134,000 on the clock)
Relayed the above information, also stated there was a tune installed (no warranty to void) and that if he needed it returned back to stock to let me know and I would. Get a call the next day that on the test drive it boosted "over 50psi" and then puked coolant. They were getting ready to pull the turbo, clean it and replace the vgt actuator as soon as it comes in today. They mentioned they were worried about the heads now...
My main question is do you think a knucklehead ramping the boost up to 50psi for a short period would stretch my ARP's?
I am having them go ahead with cleaning the turbo, replace the vgt actuator and I may go ahead and pick up a new degas bottle cap to see if that's the puking issue. They also told me they went ahead and returned it to stock after I told them to let me do it b/c I had a tuner. I guess I'll be sending my SCT back to get it unlocked now too...
Tad Abraham
2005 F-350 DRW 6.0PSD Longbox
CrewCab 4.10's and a Limited Slip - Nicknamed "TINY"
B&W 5'er/Turnover Ball on top, better MPG than my half-ton
155,000+ on the clock
SCT X3, DJ's Diesel Performace Looney 160,Tow 50 and Econ 40 Tunes
Autometer triple pillar with Trans, Boost and Pyro Ultralite II's
4" Farmboys exhaust with cat delete
ARP studs installed and EGR Valve welded by Scott @ Trucks Unlimited
tabraha is offline
post #2 of 6 Old 10-14-2009, 07:49 AM
dxusmc's Avatar
I do believe the knucklehead ramping it up to 50psi of boost definitely caused whatever made it puke coolant. I don't think it would've stretched the ARPs though, I mean thats what they meant to prevent. I think you're right on track with buying a new degas bottle cap and hoping thats the issue. But if its not, I think you know where to look next
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #3 of 6 Old 10-14-2009, 08:17 AM
Countryboy07's Avatar
Sorry to say, but you should have returned it to stock before you dropped it off. Good luck with your truck and hopefully you get everything figured out.
-French
2003 Ford F-250
6.0L Powerstroke Diesel, CC, SB, 4x4
ZOODAD mod
DIESELS FOR CHRIST
Countryboy07 is offline
post #4 of 6 Old 10-14-2009, 10:40 AM Thread Starter
tabraha's Avatar
No doubt I should have done that, I don't mind taking the SCT unlocking $ on the chin. I specifically said no re-flashing but shoulda known there's no control over that. My main concern is my ARP's/heads right now.
dxusmc I hope your right!
Tad Abraham
tabraha is offline
post #5 of 6 Old 10-14-2009, 10:54 AM
troid123's Avatar
Send a message via AIM to troid123
I dang ol shore reckon something screwed up man!!
2006 F250 CC Short Bed King Ranch 4x4 (109,000 miles)
4" Turbo Back w/ 6" Tip
SCT x3 w/ Custom Tunes From DJ's/Innovative
03 turbo
Eclipse Navigation/DVD/CD/MP3 w/ Rear Camera
Rear DVD/MP3/CD Entertainment System
Escort Passport SR7 Built In Radar Detection System
K & N Cold Air Intake w/ S&B Replacement Filter
Roll-N-Lock Retractable Bed Cover
Nitto Trail Grappler LT295/70R18
***SOLD 10/31/11***
New Truck:
2011 Ford F-150 Limited 6.2L Super Crew
troid123 is offline
post #6 of 6 Old 10-14-2009, 10:56 AM
Mine puked about 1000 miles after I got my studs put in. Replaced the cap and all has been golden ever since.
-French
2003 Ford F-250
ZOODAD mod
DIESELS FOR CHRIST
