Oil Bypass System
Well, just bought this system. Anyone tried it? Once it get's here I'll be sure to give everyone an update on what I think about it...
Oil Charge Systems - Bypass Oil Filter 6.0 Powerstroke One Micron (ocspsb)SEE BUY PRODUCT PAGE TO PURCHASE |
im thinking about this kit to. it looks good and easy as pie to install. let know how it goes!
looks like a nice set-up - but the mounting bracket puts the filter right where my coolant bypass filter sits.
![]() definitely post some pics when you install. gotta be a way to make everything fit! |
I asked about the warranty and they said, "if anything ever breaks i simply replace it at no charge." I asked about the fittings and they said, "it has a aircraft locknut, no reason for it to fail, and they can be viewed at, www.frantzoil.com;" |
Looks like a nice kit -- reasonably priced as well. My only concern is that it looks like they've used the stock plastic oil filter cap and fill plug, and drilled and tapped them. Let us know, because I could be wrong.
I just wouldn't trust the plastic. |
I have this kit. Great kit, high quality and very simple and fast to install. The bracket bolts to the 2 alternator bolts and my bracket was off a bit so I had to drill the holes out more. I did have to remove my coolant filter off and have to figure where to put it now. But I would recomend the kit to anyone on the fence.
i run the amsoil kit, it cost a more but it came with billet alumminum caps, alot stronger than than plastic. as for the mount, i went to the local metel shop and bought a piece of angle alumminum for $5.00. both kits get the job done but amsoils seems to be a higher quality.
