Exhaust smell comiong from vents? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-09-2009, 05:04 PM Thread Starter
LawDog - Premium Member
scbrown74's Avatar
When I am at a stoplight and my AC or my heat is on I get an exhaust smell from my vents. Just wondering I need to look at or if anybody else has had this problem. thanks for any answers.
scbrown74 is offline
post #2 of 9 Old 10-09-2009, 05:42 PM
Tacomarunner's Avatar
x2, but only when the heat is on...
O7 F-5504dr 4wd cab and chasis w/ 12' Scelzi service body 6spd manual trans. 200" WB 17,950 GWWR 4.88 gears
Overhead gauges w/ EGT and Boost. FCDP EGR Delete. AEM Workhorse CAI. Down pipe only, no cat or muff.
Tacomarunner is offline
post #3 of 9 Old 10-09-2009, 11:46 PM
metstroke06's Avatar
Yeah, I had that.... Just got my truck back today from the dealer. New EGR cooler, oil cooler, and head gaskets. 4k in warranty work later, its fixed!
2006 F250 King Ranch
metstroke06 is offline
post #4 of 9 Old 10-10-2009, 12:09 AM
jdstroker6.0's Avatar
Mine did the same thing for a little while bit it seemed to fix it's self. Thought I had an oil leak on or around the turbo
2008 F-250 4x4 Lariat
Nitto Trail Grappler 35x12.50x20
Stock (for now)
jdstroker6.0 is offline
post #5 of 9 Old 10-10-2009, 12:36 AM Thread Starter
scbrown74's Avatar
Was the smell from a bad EGR cooler, oil cooler, and the head gaskets or did the smell come after the listed fixes.
post #6 of 9 Old 10-10-2009, 12:38 AM
Oh it was just the coolant coming out of my degas bottle (puking). It would be hot and come through the vents.
post #7 of 9 Old 10-10-2009, 12:39 AM
Oh the reason was head gaskets, they replaced the other stuff before to see if it would still puke and it did. I just got all 3 replaced.
post #8 of 9 Old 10-10-2009, 03:21 PM Thread Starter
scbrown74's Avatar
Sure would like to find the cause of the exhuast smell in the vents. Don't know if a bad head gasket would cause my problem or not. The truck is a 2006 F-250 Crew-Cab 4X4 with 38,000 miles. I guess I will take it to the dealer to see if they can find the problem. Don't get wrong but most of the time most people don't want to here there head gaskets have gone bad but my truck has not been studded yet and it would make it easyer to get it done. The truck recently had the motor pulled for a bedplate repair and when I got it back it puked a little but I think it was over filled because I took some coolant out and it has not done it again. It might be something they did not get lined up right when they restalled the motor that is causing the exhuast smell to come through the air vents.
post #9 of 9 Old 10-10-2009, 05:36 PM
harleystroker's Avatar
Send a message via Yahoo to harleystroker
It could be your y pipes get under the truck and look to see if the bellows are blown out.
harleystroker is offline
