anyone know the difference between 03-04.5 to 04.5-07 HPOP - Ford Powerstroke Diesel Forum
Old 10-06-2009, 03:34 PM
anyone know the difference between the 03-04.5 HPOP to the 04.5-07 HPOP pumps?
Old 10-06-2009, 04:10 PM
Send a message via Yahoo to Lubbockguy1979
the later is said to be capible of more psi. but other than that i have no clue
Old 10-07-2009, 09:30 AM
can you put a 03-04.5 pump on a 05-07 6.0L turkc or visa versa?
Old 10-07-2009, 06:50 PM
The covers and outlets are completely diffenent. The early pumps are alot weaker then the later pump. If you converted the cover and stand pipes it would work, but that is a lot of work.
Not 100% but i think one is a piston pump and one is a gear pump.
Old 10-07-2009, 07:12 PM
say no to rolling coal
Bob Riley himself from Dieselsite told me that the 05 and up pumps will put out less oil than their earlier counterparts. The newer style are also more reliable than the earlier pumps. With the exception of the STC fitting troubles, he said he's never seen a newer pump itself fail. There was a design flaw with the earlier pumps, something to do with the way the gear was threaded on to the shaft IIRC. The earlier pumps do provide more HPO, but are more prone to failure is what I took from our conversation this past spring. If you really want to know more give him a call. He's a good guy with a wealth of knowledge I'm sure he'd be happy to share if he has the time to talk.
Old 10-09-2009, 01:14 PM
the 03-04.5 are a swash plate style and the later are a piston pump. and you would basically have to swap everything over to make it work
