fuel/water separator. - Ford Powerstroke Diesel Forum
Old 10-06-2009, 05:59 AM
How often do you guys open the plug on the separator and drain the water out? I was just wondering, it appears that whomever got hold of mine last stripped out the 6mm allen head and I am not sure how I am going to get it out now. I have heard some mechanics say that they recommend doing this every few weeks or so, but I have heard others say that they just wait till the light comes on.
Old 10-06-2009, 07:45 AM
You could try an easy out that should work.
Or you could just take the end cap off....I think that drains it too.
Old 10-06-2009, 03:02 PM
Try to drain it atleast once a month.
I've never had a fuel in water light thus far.
If you get the plug out, International and Ford offer a plug that you can screw in by hand, you should definately get one!
Old 10-06-2009, 05:59 PM
I drain mine once a month. Here is the new drain plug...HFCM Drain Plug
Old 10-06-2009, 06:13 PM
Where is the separator located on a 2007 6.0?
Old 10-06-2009, 06:14 PM
On the driver side frame rail near the transmission.
Old 10-06-2009, 06:26 PM
Thanks... Better start off by draining it first off.
Old 10-07-2009, 08:48 AM
I am going to pick up a set of easy outs, and see if mine will come loose, but damn its in there tight and it seems like a fairly soft, malleable iron, so I dont know if an easy out will get it or not, but I will try. thanks for the info.
Old 10-07-2009, 05:42 PM
Changing the filter does NOT drain the water separator.
You can epoxy a 6 mm allen wrench in the stripped plug and most likely get it out.
Old 10-07-2009, 05:49 PM
Nice idea, I like that.
