Weight of Engine(s) - Ford Powerstroke Diesel Forum
Old 10-03-2009, 08:08 PM
Weight of Engine(s)
Does anyone know the weight of the 7.3 6.0 and 6.4 engines? What about the new 6.7 (not really interested in that one as much, but would be neat to know for comparison)
I have a crazy idea in mind and need to know weight.
Old 10-03-2009, 08:13 PM
The 7.3 is lighter than a 6.0 at 930lbs dry. The 6.0 is marginally heavier at about 1050, and I'm not sure about the 6.4.
Old 10-04-2009, 07:11 AM
Lt. Negativity
I think once heard the 6.4 was 1100 or 1200 I believe.
Old 10-04-2009, 08:37 AM
sounds about right..........
Old 10-04-2009, 08:52 AM
Here's some specs from 6.4L_overview.pdf
Engine Type .................................................. .........................................Diesel, 4 Cycle
Configuration .................................................. ..............4 OHV/1 Cam-in-Crankcase-V8
Displacement .................................................. ...................................390 cu. in. (6.4L)
Bore & Stroke .................................................. ..............3.87 X 4.134 (98.2 X 105 mm)
Compression Ratio .................................................. ...........................................17.5:1
Aspiration .................................................. ...............Series Sequential Turbo with CAC
Rated Power @ RPM .................................................. ........................350 @ 3000 RPM
Peak Torque @ RPM .................................................. .........................650 @ 2000 RPM
Engine Rotation, Facing Flywheel .................................................. ..Counter Clockwise
Combustion System ...................................High Pressure Common Rail Direct Injection
Total Engine Weight (auto with oil) ................................................11 30 lb. (498.95 kg)
Coolant Flow (to radiator)....................................125 gal/min (473 L/min) @ 3000 RPM
Air Flow @ RPM (compressor inlet).......................744 CFM (21.1 m3/min) @ 3000 RPM
Exhaust Flow @ RPM (engine outlet)..................1962 CFM (55.6 m3/min) @ 3000 RPM
Oil Flow @ RPM .................................................. ...13 gal/min (59 L/min) @ 3000 RPM
Cooling System Capacity (engine only) .................................................. 25.3 qts (24 L)
Lube System Capacity (including filter) ................................................15 qts. (14.2 L)
Firing Order .................................................. ......................................1-2-7-3-4-5-6-8
