Changing anti-freeze
Anyone have trouble changing there anti-freeze in the 6.0 because of the egr cooler ? Wondering if I can just do it at home or should I take it somewhere ?
Thanks . |
You need to go to this web site, powerstrokehelp.com this guy discusses specific problems u can run into if u put in the wrong antifreeze.
Diesel Coolant Change
Don't forget to check for proper nitrite level after you have added your coolant. Any competent diesel shop should be able to check it for you, usually at no cost. I'm not sure if the Ford coolant comes preloaded with nitrite. This is extremely important in order to avoid cavitation around the cylinder walls. The nitrite level should be checked once a year anyway whether or not you change your coolant.
If you are replacing it with the factory gold coolant it should be pre-charged with the proper addetives. If you are swapping the green in for the gold then yes you need to buy a bottle of the ford coolant addetive.
the only thing you should use is gold coolant. no water
Thanks for the advice everyone and I will check out that web site tomorrow .
