Surface heads while doing studs???? - Ford Powerstroke Diesel Forum
Old 09-30-2009, 07:44 PM
Well, I found a good deal on studs so they will go on the shelf while I gather gaskets, seals, probably the EGR delete, but was wondering...
Now, I have the Ex, so I planned on lowering the motor (remove the mounts) and changing the studs one by one instead of breaking the motor open. Should I take a few more days (and a few hundred more dollars {~500ish?}) and pull the heads and have them surfaced? I know Ford sucked at getting them flat, but I don't have leaks or milk in the jug so should I yank the heads or just do the studs one at a time?
Old 09-30-2009, 07:49 PM
check it before. but it wouldnt be a bad idea.
i had mine done while they were off
Old 10-01-2009, 02:02 AM
Yes spend the time & money or is just a waist of you time.
