Using High Idle Mod
Ok so this morning was a little chilly so I decided to use the high idle. My question is does it hurt anything to just let your truck idle at the 1250 mark like that? I only let it idle for about 5 minutes then I was off to work...
I want to know too since the snow has started to fly here. I've heard idling the 6.0 isn't good for it, but maybe using the high idle is better?
its better for it to idle at the 1200 mark then 650. i doesn't hurt anything.
the high idle is better than a normal idle for prolonged periods. It don't dirty the egr as bad
I ususally fire mine up, let it run for a minute, then put it on high idle for a few minutes. I do it everyday for the most part
On cold starts or any start (before using the mod) let the eng idle normal for -at least 30 seconds-. There is all kinds of start up programming !especially cold starts! and the mod well effect them. It would be best to let it have a normal idle a for a lil bit to get eng through its start up procedure, then use the mod.
is this a tuning mod? or how do you aquire it?
Do a search for "high idle mod" and you will find some info on it. Basically you hook two wires that are under your dash to a switch and have a high idle when its on.
the advantages?
