Tips for replacing power steering pump - Ford Powerstroke Diesel Forum
Old 09-29-2009, 10:09 PM
Having nothing but great luck with the new truck. (05 F250, 6.0)
Driving to work this morning, go to make a lane change and my steering is HEAVY. The pump (I'm assuming!) died instantly! No hydroboost brakes either. No noise, nothing. It's like there's no belt running to the power steering pump but I double checked it's still there and spinning.
I'm assuming the pump died. Fortunately pumps are cheap but I can't find a ton of info on replacing them. It looks fairly straight forward but I've never dealt with hydro boost brakes so I'm thinking the bleeding procedure may be more complicated.
Does anyone who has replaced the pump have any tips or advice? Can't decide whether to go with a $70 Napa rebuilt pump or a $100 low mileage OEM pump.
Appreciate any help!
Old 09-29-2009, 10:47 PM
Just had a bout with rebuilt Motorcraft pumps,three in a row all too weak.ford finally found a NEW pump in rebuilt box,all is well. A bulletin states you can transfer the pulley thre times,that's correct on fourth pump had to buy new pully as well.There may be new elsewhere,I'd stay away from rebuilt if possible.2.0 HR. job at least with all tools
Old 09-30-2009, 10:21 AM
That means it will probably take me at least 4 hours. Thanks for the info.
Old 04-16-2012, 06:41 AM
what tools are needed and can anyone give me some directions on swapping this pump any help would be appreciated
Old 04-16-2012, 07:27 AM
Does anyone make an up grade pump to get rid of hard steering when not moving. Makes it a pain when backing a trailer. 176k miles on an 04 F350 4x4, do others have this issue.
Old 04-16-2012, 08:49 AM
I have 170,000 on my 06 and have the same issue. Until this thread thought I was looking at a PS pump, guess I'll hold off.
Old 04-16-2012, 09:45 AM
Turbos = Witchcraft
When I did mine, I was able to reach from underneath the truck. Removing hte lower radiator hose made ti easier to get to. There are only two hoses that attach to the pump. I just disconnected those, then removed the 4 bolts that hold it in place.
The only special too I needed was a powersteering pump pulley remover, made by snap-on. I borrowed it. I tmade the pulley removal and reinstall super easy since the new pump won't come with a pulley.
