Injector Cleaner
Have a 2005 6.0 Liter with 40,000 miles. I have heard how expensive the injectors are and was wondering if there was an injector cleaning I can add to the fuel that would clean them. I am not big on fuel additives but I would be willing to try one if has proven results. Any info would be greatly appreciated.
Power Service white and gray bottle. White bottle in the Winter time, it keeps you from gelling up, cleans injectors, boosts cetane, etc. That's what I use.
You can also run 2 stroke oil thru it , but you have to get the 2 stroke outboard motor oil, blue bottle at walmart it says TCW-3 on it. Helps your truck runs smoother and quiter as well.
i run stanadyne performance formula all year round. IMO this is the best additive on the market, its the only fuel additive that is made by an injector pump manufacturer. i run it in every tank and have had 0 problems, runs great and improves fuel mileage abit. 86000 miles and counting on original injectors.
I run stanadyne when I can find it, and power service every tank in the winter. Last couple tanks I put my Klotz 2-stroke snowmobile oil in and my truck loves it. Its a injection/premix oil TCW-3.
Anyone have a pic of the oil used and also how much per gallon?
good, new, clean fuel, SEAFOAM works very well, stanadyne. 2-stroke oil is a good idea as long as you get the right kind, and dont put too much.
Have any of you read the report about all the diesel fuel additives for lubricity, none of these were good options from what I recall.... let me see if I can dig it up.
I do know that 5% bio diesel was at the top of the list and right below that was Opti-lube XPD, which I use a lot. |
Here you go...
Ranking Additive HFRR Score Improvement Over Base Fuel Blend Ratio Dose Oz. per 26-Gal Tank MSRP $ Cost per 26-Gal Tank COMMENTS Desired Engine Manufacturers Assoc DESIRED < 460 Desired by the Engine Manufacturers Association Standard U.S. Standard < 520 U.S. Lubricity Standard for ULSD fuel Baseline Untreated ULSD #2 Diesel Fuel 636 Baseline fuel used in this study 1 2% REG SoyPower Biodiesel 221 415 50:1 66.56 Market Soybean based bio-diesel 2 Opti-Lube XPD 317 319 256:1 13.00 $4.35 Multi-purpose + anti-gel, Cetane improver, Demulsifier 3 FPPF RV, Bus, SUV Diesel/Gas Fuel Treatment 439 197 640:1 5.20 $2.60 Gas & Diesel - Cetane improver, Emulsifier 4 Opti-Lube Summer Blend 447 189 3000:1 1.11 $0.68 Multi-purpose, Demulsifier 5 Opti-Lube Winter Blend 461 175 512:1 6.50 $3.65 Muti-purpose + anti-gel, Cetane improver 6 Schaeffer Diesel Treat 2000 470 166 1000:1 3.33 $1.87 Multi-purpose + anti-gel, Cetane improver, Emulsifier, bio-diesel compatible 7 Super Tech Outboard 2-Cycle TC-W3 Engine Oil 474 162 200:1 16.64 $1.09 Unconventional - (Not ULSD compliant, may damage 2007 or newer systems) 8 Stanadyne Lubricity Formula 479 157 1000:1 3.32 $1.00 Lubricant, Demulsifier, Detergent, Anti-Oxidant, Corrosion Inhibitor, Alcohol-Free 9 Amsoil Diesel Concentrate 488 148 640:1 5.20 $2.16 Multi-purpose - Demulsifier, alcohol free, bio-diesel compatible 10 Power Service Diesel Kleen + Cetane Boost 575 61 400:1 8.32 $1.58 Multi-purpose - Cetane improver, bio-diesel compatible, alcohol free 11 Howe’s Meaner Power Kleaner 586 50 1000:1 3.32 $1.36 Multi-purpose -Alcohol free 12 Stanadyne Performance Formula 603 33 480:1 6.93 $4.35 Multi-purpose + anti-gel - Cetane improver, Demulsifier, Detergent, Anti-Oxidant, Corrosion Inhibitor, Alcohol-Free, 5% bio-diesel compatible 13 Used Motor Oil Shell Rotella T 15W-40 5,000 miles used. 634 + 2 Insignifficant 200:1 16.64 $0.00 Unconventional - (Not ULSD compliant, may damage systems) 14 Lucas Upper Cylinder Lubricant 641 - 5 Insignifficant 427:1 7.79 $2.65 Gas or Diesel 15 B1000 Diesel Fuel Conditioner by Milligan Biotech 644 - 8 Insignifficant 1000:1 3.32 $2.67 Multi-purpose, canola oil based additive 16 FPPF Lubricity Plus Fuel Power 675 - 39 1000:1 3.32 $1.12 Multi-purpose + anti-gel - Emulsifier, alcohol free 17 Marvel Mystery Oil 678 - 42 320:1 10.40 $3.22 Gas, Oil and Diesel fuel additive - (NOT ULSD compliant, may damage 2007 and newer systems) 18 ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive 696 - 60 1000:1 3.32 $2.38 Multi-purpose - Cetane improver, Emulsifier, alcohol free 19 Primrose Power Blend 2003 711 - 75 1066:1 3.12 $1.39 Multi-purpose - Cetane boost, bio-diesel compatible, Emulsifier Products 13 through 15 had a statistically insignifficant effect on the HFRR score compared to the baseline fuel. Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant. DIESEL FUEL LUBRICITY ADDITIVES STUDY RESULTS Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the strictest requirements requested by the Engine Manufacturers Association. Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel. Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will be investigated. Copyright© The Diesel Place & A. D. Spicer August, 2007 There is an actual article wrote up by the diesel place, that describes this with a LOT more information and a lot easier to read, but you catch the drift. |
ok whats the difference you guys are talking about in getting the right two stroke oil. Almost all oil now is TCW-3 anyways and it doesnt matter pre mix or oil injection. I use both in my snowmobiles, dirt bikes, fourwheelers.
