I would like somebody to run a oasis report for me if you don't mind. - Ford Powerstroke Diesel Forum
Old 09-22-2009, 06:55 AM
I am just wanting somebody to run a oasis report for me. I just bought a
2005 F-250 Crew Cab Long Bed FX4 with 78500 miles.
Vin# 1FTWW31P35EB16115
I had only had it for 3 days when the FICM went out. Just wondering what other problems it has had. Thank you in advance.
Shae Pettigrew
Old 09-22-2009, 06:57 AM
My E-mail is: shaep@cableone.net Thank you.
Old 09-23-2009, 05:07 AM
Anybody? Please.
Old 09-23-2009, 05:18 AM
cant do it for 2 reasons-
1) They can't pull them anymore- Much more important than point 2 which is...
2) You do not appear to be a premium member (regular people are not eligible)
Maybe your local Ford dealer can help you. Freak chance a member might help you out...not likely in this instance as Ford seems (or something) to have clamped down on such private info.
Old 09-23-2009, 05:49 AM
Ok. I didn't know either one of those things. I was told by a guy that used to work for ford to just ask and somebody would likely help me. I didn't realize that being a premium member had anything to do with it. How does that work?
Old 09-23-2009, 05:50 AM
Go to psn i think they still do them
Old 09-23-2009, 05:58 AM
So if you ask for it will a dealer do it, if you know them or whatever. Thats dumb that the info is locked down now. It really helped out truck buyers
I had one done last spring on a truck and the dealer was like ah yea the carfax shows up clean. But I knew better. I got the vin from him and came on here and posted up that I wanted an oasis done. The oasis was LONG and consisted of pulling the heads 3 times, blown head gaskets, injector failures, transmission failure, turbo failure, numerous sensor issues. Some old poor fella bought it the next day.
The truck was a 2004 F-250 Charcoal Grey ex cab SB. 140k for like 11,500. Too good to be true. They knew the deal on the truck. If its to good to be true chances are it probably is
Old 09-23-2009, 06:03 AM
Almostdunfukinwidit
Last I checked they werent either. For the same reason I cant anymore
Old 09-23-2009, 07:34 AM
Man that sucks. My truck is an 05. It is really clean. Underneath it there isn't a speck of dirt or grim or rust. I really looked it over good. It has a 6" lift and drives down the road straight as an arrow. You can let go of the wheel and it stays perfectly straight. Has good power and sounds good. The engine bay is really clean too. I just wanted a little piece of mind.
