2005 front brakes torque specs? - Ford Powerstroke Diesel Forum
Old 09-21-2009, 04:34 AM
I changed the front pads on my '05 over the weekend, but I didn't know the torque specs at the time. Are these correct?
Front brake caliper pin bolts - 56 lb/ft
Front brake caliper anchor plate bolts - 166 lb/ft
How important is it to be torqued to those specs? I'm pretty sure I'm a bit over on the pin bolts, and more than likely under on the anchor plate bolts.
Also, does anyone know what to torque the lug nuts to with steel wheels?
Thanks.
