injector change 03' 6.0 - Ford Powerstroke Diesel Forum
Old 02-28-2007, 02:59 PM
anyone done it before? i seen the procedure and it doesnt look to bad but dont kno if i need any special tools..i might have me a bad #1 so i was thinkin of doin all of em with some 50hp injectors from one of the vendors..anyone got any helpful hints
im thinkin its prob pretty time consuming but i can take a weekend and do it right
Old 02-28-2007, 06:30 PM
bumpity bump bump
Old 02-28-2007, 07:52 PM
well lets bump it again and keep it going for you partner. i am unsure but will see if i can find some info on that for you, or maybe marc could chime in and see what he says.
Old 03-02-2007, 06:42 PM
ima gonna give it one more BUMP before i give it up......
Old 03-03-2007, 01:29 PM
Using a 19 mm (0.74 in) socket, push the fuel injector electrical connector out of the rocker arm carrier.
Prior to removing the injector assembly, insert clean shop towels in the oil drain holes adjacent to each glow plug.
CAUTION: Failure to account for all snap rings or pieces of snap rings prior to placing the vehicle back in service can cause engine damage. A missing snap ring can be ingested into the lube oil system causing severe engine damage.
CAUTION: To prevent engine damage, do not use air tools to remove the fuel injectors. The snap ring that extracts the injector can dislodge and fall into the oil drain hole.
NOTE: If engine oil is found in the engine coolant or engine coolant is found in the combustion chambers, new injector sleeves may need to be installed.
Remove the bolt, the fuel injector hold down and the fuel injector.
NOTE: If a snap ring or piece of a snap ring is missing from the injector hold-down assembly, it must be located prior to removing the shop towels.
Remove the shop towels.
this is what i found on the cd i have sounds like remove the bolt and snap ring and it comes right out
