Gonna do filters - Ford Powerstroke Diesel Forum
Old 09-12-2009, 08:41 AM
Rob Rob is offline
Gonna do filters
I need to change my fuel filters today, but im gonna save some $$$ and do them myself. Anything i need to know before i do this?? Anything I need to do after they are replaced and everything is put back together?? Any priming needed??
Old 09-12-2009, 08:45 AM
I would make sure you have the socket to change the filter on the frame rail. It is a pita without one.
Old 09-12-2009, 08:48 AM
Rob Rob is offline
know what size offhand???
Old 09-12-2009, 08:49 AM
I want to say 36mm but don't hold me to it. Ill check quick.
BE CAREFUL!!!!!! Don't strip the plastic cap. And I use an oil filter wrench to get them off. Hope that helps
Old 09-12-2009, 08:50 AM
Almostdunfukinwidit
No priming necessary. IIRC its 36mm socket for the one on the frame. And a 24 for the one up top.
Just remove the covers replace the O rings and filters. Hop in the truck cycle the key on and off a couple times. Then fire it up
Old 09-12-2009, 08:51 AM
Almostdunfukinwidit
Oh and wear something that you dont care if diesel gets on it
Old 09-12-2009, 08:52 AM
Yep its 36mm. It isn't to bad of a job. I would wear a shirt you don't mind ruining though. You probably will get diesel on it.
Edit: Dave beat me to it
i agree with dave when i use to stock fuel system i would do it that way, and i also replaced the water drain with the upgraded one, it was like 20 bucks, i think i use to drain that so that i didnt get a fuel bath before pulling the filters out
Old 09-12-2009, 08:58 AM
Very important!
