Quick question for you 6.0 guys. - Ford Powerstroke Diesel Forum
Old 09-10-2009, 11:57 AM
My dad is looking into getting a 2005 f250 with the 6.0L. I am trying to find info on some of the problems that he might encounter. I myself have a 6.7 cummins and know that all of these newer truck have their own problems. Any information on problems that occur often and how to fix these problems before they happen would be very appreciated. Thank you. I should throw in here that i know nothing about powerstroke at all so ANYTHING would be helpful.
Old 09-10-2009, 12:10 PM
most common problems:
EGR related issues, bad design most common fix is to delete the whole egr system
head bolts/blown head gaskets. weak head bolts that cause the gaskets to let go. common fix for that is to replace the gasket and install ARP head studs. since its an 05 it will still have factory warranty if its under 100k
those 2 things are pretty much the most common problems that you will run into, you may not it just depends. get an oasis and see what has been done to the truck prior to buying and see what was replaced.
Old 09-10-2009, 02:30 PM
Oasis?
What is an Oasis? ( And don't tell me a small body of water is the desert!)
Thanks
Old 09-10-2009, 02:36 PM
Also here is another page that could help What to look for when buying a used 6.0L
Old 09-10-2009, 02:49 PM
Almostdunfukinwidit
Thanks
O.A.S.I.S stands for Online Automotive Service Information System. An Oasis report is a list of all warranty repairs done by ford
Old 09-10-2009, 08:41 PM
its a small body of water in the desert
Old 09-10-2009, 08:48 PM
LoL...Water !!!
Old 09-11-2009, 03:37 PM
Thanks alot guys.... I appreciate the info
Evan...I told you not to tell me ..."it's a small body of water in the desert " !! ha ha
have a great weekend
Old 09-11-2009, 05:25 PM
not a problem man. post up some pictures if your dad gets the truck. good luck
