Maybe a HPOP problem? Help?! - Ford Powerstroke Diesel Forum
Old 09-08-2009, 05:52 PM
ok so when my truck sits over night and i go to crank it in the mornin, it starts real funny and idles very low and sorta lopes for a second until my oil pressure gauge jumps up then it begins to idle normal, is my hpop showing signs of giving up?
Old 09-08-2009, 11:17 PM
Lt. Negativity
Could be, maybe icp, maybe your hpop or lpop
Old 09-09-2009, 03:14 AM
Powerstroke Techie
check codes, could be a high pressure oil concern, but there's a fairly good chance that this is an injector concern.
Old 09-09-2009, 03:34 AM
Feedback Score: 5 reviews
couple of injectors are probably bleeding off pressure, this will cause a cold start issue everytime. Its probably not going to set any codes
Old 09-09-2009, 04:21 AM
The guage on the dash is LPOP. It is taking a while to build pressure? It sounds as if you need to put a guage on to see if it is pumping enough.
Old 09-09-2009, 03:37 PM
figured the problem out today at work, hooked the genysis 3.0 up to it and found out that cylinder 7 has malfunction, ran to local diesel shop and bought a reman injector for 174 and im off tomorrow so ill be gettin that done asap, im gonna take pics during removal and installation for the tech forums in case theres alot of us who do it ourselves to save money.
