Link to 6.0 Fuel Filter Maintenance - Ford Powerstroke Diesel Forum
Old 02-25-2007, 07:46 AM
RET RET is offline
How to drain the HFCM and change your Fuel Filters.
FUEL/WATER SEPARATOR DRAIN PROCEDURE
Old 02-28-2007, 10:10 AM
Send a message via AIM to 6.0Sean
Thanks RET, that helped me out a bunch since its my first time doin fuel filters on my truck. beepbeepbeepbeep those things are expensive though!
Old 02-28-2007, 11:12 AM
Go to an international dealer and get them. I don't remember the part # but they're about 35 for the set with the aquabloc membrane on the primary.
Old 02-28-2007, 12:29 PM
RET RET is offline
Glad you found the link to be some use...Its not too hard of a job to change the fuel filters, but its nice to have some instruction on the first go-round.
RET
Old 02-28-2007, 03:56 PM
Thanks, RET I'm still 10k away, but I am glad to have read this. The frame-mounted filter sure is buried in tight I checked it out a couple of weeks ago when I put in my cat delete pipe. A whopper like me with huge hands is going to have a tough go, but it seems pretty straightforward.
Thanks
Old 02-28-2007, 04:15 PM
RET RET is offline
Yup the front drive shaft on the 4x4 makes it a bit of a PITA to get at.
I used a combo of an oil filter wrench and channel locks, (But I'm 5-7 and 145 lbs.....I could just about crawl up in there and use my teeth if I had to :-)
I would suggest investing in a socket or box end wrench that fits the nut head on the top of the filter cap.
Nothing makes it easy like having the right tool for the job.
