There's a bracket behind my power steering reservoir, it seems like something should be there, and there's some cut wires above it, but I can't find anything about it.
The wires are the through firewall wires for add-on accessories. Look under the dash near the parking brake and you will see the exact same color wires going to nothing as well. In 03 Ford started doing this to prevent people from drilling through the firewall to run wiring to accessories. The empty rack is usually on 2wd models when the 4x4 t-case motor relay goes, or on 4x4 models with the t-case shift lever on the floor and NOT SOF.
It's a 2wd but the previous owner ran the trailor brake through the firewall with the rest of the harness
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
