ABS Light came on for no apparent reason? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-19-2007, 07:23 AM Thread Starter
This weekend after driving appr. 230 miles, in my 05' PS CC, along the interstate, not even hitting the brake the yellow ABS light came on, and stayed on until I stopped for fuel. After re-starting the truck, no light and goning back home on the reverse trip, 250 miles no light? What could have been going on, any suggestions? Thanks in advance.
bama711 is offline
post #2 of 2 Old 02-19-2007, 07:28 AM
DKR
<--Pro Cooler Racer
DKR's Avatar
On an older E150 we had the ABS and sometimes the Brake light on because of low fluid...it could be some interference in one of the sensors..road dirt, salt..or a bad wire/connection...I wouldn't worry too much till it came on again...if the ABS light is on w/o the Brake light..then the ABS system is disengaged, brakes will still work.
Eric
2007 F250 6.0l King Ranch CC LB
Sponsored by Innovative Diesel Performance
SCT XCal2 w/ Custom Files & FICM tuning
DashDAQ Series II; ARP Headstuds; AFE Stage 2 XP Intake w/ Proguard 7
Industrial Injection 190cc injectors; FASS 150/180; ITP Regulated Return
'03 Turbo Swap; Zex N2O Dry Shot; CFM Smallmouth Intake Elbow
Zoodad w/ Predator Screen; MBRP 4" Cool Duals Straight Piped
EGR Delete w/ full manifold; Coolant Bypass Filter; Train Horns
Eclipse AVN62D; High Idle Mod; BFG ATs 285-65/20s
Truck- 12.51sec @ 108mph @ ~7700lbs (1/4 mi)
Cooler- 39.93sec @ 12.12mph @ ~180lbs (1/8 mi)
Email:
DKR is offline
