Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 08-13-2009, 06:01 PM
agamache agamache is offline
Reliability?
How reliable would my 6.0L be if I do an egr delete, head studs, and ran sct tunes. I am a little over 50,000 on the clock, Could i make it to 100,00 thousand without any major trouble?
Thanks
Old 08-13-2009, 06:02 PM
I meant to say sct with custom tune like the extreme street and extreme race
Old 08-13-2009, 06:05 PM
Landonschert Landonschert is offline
umm you should be good just replace all your O rings on your oil rail why your are in there
Old 08-13-2009, 06:09 PM
chuckles chuckles is offline
Send a message via Yahoo to chuckles
From what I hear, studding, HPOP T Fitting mod ( V pumps only), egr delete, good tunes (SCT), and re routing some of the wiring (chaffing issues), cures most of the newer 05 and up 6.0 problems. The earlier 6.0 also had more issues with HPOP and injectors.
Old 08-13-2009, 06:11 PM
2006PSDSD 2006PSDSD is offline
ΜΟΛΩΝ ΛΑΒΕ
You could hit 100k without that stuff, you're probably going to be looking at well over 200k if you do those things (without issues that is). The 6.0 is a great engine, but the EPA MADE it unreliable
Coolant filter system is a must also.
Old 08-13-2009, 06:12 PM
04 doesn't have the T fitten only V pumps 05-07 just my 0.2
Old 08-13-2009, 06:14 PM
Is it safe (blown head gaskets)to run the extreme street or extreme race without studs
Old 08-13-2009, 06:15 PM
yes, that is true, but earlier hpops had other problems. That is why that went to V 4 style pump from the older swash plate style. I should clarify this.
coolant filter was installed about a month ago. Cant wait to see whats inside
