Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 02-24-2006, 05:13 PM
autoxsteve autoxsteve is offline
New member - maintenance Qs
Hi. I'm new to this forum. I've got a 2003 Ford F250SD Crew Cab with the 6.0L powerstroke.
I've got a question.
How in the heck do I change the belt in this beast?
I pulled a couple of the snap on shrouds on the fan and it appears that I need to remove the shroud cover that fits between the engine and the radiator shroud.
Had anyone done this?
Thanks in advance...
2003 F250SD Crew Cab, Powerstroke 6.0L, 45k miles. Bone stock...
Old 02-24-2006, 05:24 PM
mschn99 mschn99 is offline
you dont need to change the belt till 100k.......and if it is shredding, you have one of two problems. if it isnt, leave her till 100k. as far as how to do it. the easiest way is first to pull both radiator mounts from the top (two 8mm(5/16) each) to allow the one shroud to slide out easier. pull the two bolts on the shroud and carefully slide it out. then there are 4 or 5 (depending on build date) 15mm bolts holding the other shroud to the block. it will have two on the top and two on the bottom, and some build dates also have one on the drivers side almost half way down. also disconnect the electrical connector for the fan clutch. you can not take the shroud off without taking the fan off, but you can replace the belt without taking all that off, you just need the shroud to pull far enough away to get to the belt, which you get by just un bolting it............Marc
Old 02-24-2006, 05:30 PM
super_stroke super_stroke is offline
Power Strokeaholic
oh oh oh.............i can handle this one. this is so super easy. any one can do it. step 1-go to the fridge, retrieve beer. step 2-open said beer. step 3- and this is very important.....
wait for marc (mschn99) to reply
man i'm bored. sorry i couldnt give you any useful info.
Old 02-24-2006, 05:31 PM
Power Strokeaholic
DARN IT MARC!!! why am i always late??????????
Old 02-24-2006, 06:39 PM
sorry......guess i type too fast.....i didnt mean to spoil your joke ......but seriously.......how long ya been waitin to use that one ???......sounds to me like you had that one thought up and were just waitin for the time to use it
Old 02-24-2006, 08:20 PM
Power Strokeaholic
i actually just thought that up as i was typin it but i got distracted with the t.v. and didnt get it posted in time. the good ones come and go with the wind so might as well take advantage of it right? not sayin thats a goodun but its the best i had.
Old 02-24-2006, 08:21 PM
hey....you made me laugh.......not that that is too tough tough....but i got a kick out of it.......Marc
