what is the best egr delete kit - Page 3 - Ford Powerstroke Diesel Forum
 1Likes
post #21 of 36 Old 08-08-2009, 04:39 PM
bulldog84's Avatar
First Coast Diesel Performance, in my opinion, has the best egr delete available. Also, I would recommend using River City Diesel headgaskets with ARP Head Studs.
2004 F-250 FX4 6.0L
Full EGR Delete (First Coast Diesel Performance)
SCT SF3 (Innovative Diesel Custom Tuning)
Black Onyx Head Gaskets (River City Diesel)
Coolant Filtration System (Dieselsite)
4" MBRP Turbo Back Straight Pipe
K&N FIPK w/S&B Filter
BFG A/T's 285/75/16
ARP Head Studs
2" Leveling Kit
Edge Insight
Zoodad Mod
Recon Lights
New FICM
03 Turbo
OIF Army Veteran
bulldog84 is offline
post #22 of 36 Old 08-08-2009, 04:45 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Originally Posted by mcflan View Post
Thats not necessarily true. The EGR delete makes doing the studs somewhat obsolete
Unless you're boosting out the ***, its not necessary...
The reason why you get a head gasket blown is because engine coolant gets in the cylinders. Another problem with the EGR, your taking exhaust filled with carbon and recirculating it through your intake manifold. There was a pint of carbon in my intake manifold when I deleted my EGR. You can still bore out the head with the ARP studs... Assuming you delete the EGR the high strength head bolts aren't required.
Originally Posted by 2d2live View Post
I have it on authority of a Ford diesel tech that EGR delete will eliminate blown head gaskets, and he has seen a stock 6.0 pull 700hp on a dyno...... but hey go ahead and spend your money.............
An EGR delete will slightly lessen the chances of blown gaskets. But whoever told you it totally eliminates blown gaskets is A) Either a liar or B) Doesnt know what they are talking about
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #23 of 36 Old 08-08-2009, 04:47 PM
Abrannan19's Avatar
Feedback Score: 5 reviews
Dave is dead on, iEGR deletes will lessen your chances or reduce the risk of blowing headgaskets but it will not prevent blown headgaskets, you can take that to the bank.
Adam Brannan
Abrannan19 is offline
post #24 of 36 Old 08-08-2009, 05:16 PM
Talk about fantasy world ............
The main issue with any debate is longevity. One data point on one dyno, on one day (but I really even doubt the validity of this) .....
Torque-to-yield bolts are just as the name describes. They stretch - a little bit at a time. Each time they stretch they weaken. A little bit at a time and then they start leaking. Happens very slowly at design cylinder pressure and temperatures - assuming that the torquing was correct, the heads and deck were flat, etc. Even though it happens slowly, it still happens.
Eliminating the EGR system can keep coolant out of the intake and it can reduce the likliehood of turbo sticking. These are good things for sure, but there are many other ways that overboost can occur and combustion temperatures can soar.
Studs are a requirement for LONG-TERM reliability - even stock.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #25 of 36 Old 08-08-2009, 05:33 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Stock 6.0 pull 700hp on a dyno
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #26 of 36 Old 08-08-2009, 07:21 PM
CCSBD's Avatar
Ford94stroker likes this.
***SOLD***
'04 CrewCab ShortBed 6.0 4x4
Black FX4 Sport
6K HID's
CCV Mod
03 Turbo
6.4 Banjo's
Zoodad Mod
4.5" Icon Lift
High Idle Mod
ARP Headstuds
RCD EGR Delete
Updated FPR Spring
Sinister Coolant Filter
Recon Smoked Cab Lights
SCT X3 Tuned by Innovative
4" MBRP SS Turbo Back Exhaust
ISSPRO EV pyro, trans, boost guages
CCSBD is offline
post #27 of 36 Old 08-11-2009, 03:37 PM
I think the point was a stock block 6.0 could pull 700 hp. Not that a stock 6.0 produced 700hp. Coolant in the intake increases head pressure which when combined with chipped engines leads to head gasket failure. EGR delete "eliminates" coolant in the intake mfld. Obviously there are other sources of head gasket failure, i.e. the head gasket/
2d2live is offline
post #28 of 36 Old 08-11-2009, 04:49 PM
I replaced my head gasks, and deleted my egr cooling tube a week ago and my truck has been running horrible ever since. used to get 430 to a tank, now getting 250 and blowing all my fuel out the exhaust. SOMEBODY HELP!
freeman is offline
post #29 of 36 Old 08-11-2009, 05:34 PM
always best to start a new thread.
sounds like you screwed up a injector while doing the other work.
blood is offline
post #30 of 36 Old 09-25-2009, 02:49 PM
I have an 05 F250 and i noticed I was losing coolant. It has the banks big hoss kit. I did some research and decided to go with the erg delete kit for 150$ on eBay. Just got my truck back and now it is running like crap. Before it ran fine and now it has a 20% miss to it. The coolant system is over pressurizing. We took it for a drive and the harder you get on it the higher the air pressure. I think i have a bad head gasket? My truck is under warranty but I'm unsure if the new egr delete kit will void it or not?? 97,000 miles banks kit was put on around 45,000 miles or so. does anyone know if this kit voids warranty or will they not notice it when i bring it in for tests?
Duke9333 is offline
