I'm hearing a bit of a rumble when I drive, particularly on turning and when I lifted the front D/S wheel and gave it a spin, I can hear and feel the grumble, so I'm guessing it's time for a wheel bearing... or rather the hub assembly.
I know that the Motorcraft will last a long time, but the truck does have 330,000km on it, and I don't know that I'll get another 300,000.
The best price I can source on the Motorcraft is $605 and the Timken is $380.
Just wondering peoples thoughts on the Timken bearings. Parts guy told me the SP940200 part number indicates it's not an actual Timken. No idea if that's true or not.
I'm assuming he's a retailer. Problem is I'm in Canada and he's likely in the US, and shipping/duties/brokerage is a deal killer but I'll follow up on that now in hopes that it all goes well. Thx!
parts guy is a knuckle head Timken SP940200 Wheel Bearing and Hub Assembly is what you want
the Ford Motorcraft is also a Timken but comes with the 4 studs
It looks like they just sell fancy bits. I think I'll go with the Timken then.
Thanks for the info folks.
What other bits do I need when doing this job? It looks like the Timken doesn't come with the studs, are they reusable?
Also I think there was some TTY bolts that I need to get?
no TTY and the studs are reusable if they come out with the double nut trick
you need a decent pair of snap ring pliers and all the seals plus a seal installer tool if you do that as well
might want to do u joints if you go that far or just the unit bearing actually I think the Timken comes with it's o rings so maybe just a 4x4 selector hub gasket kit that comes with new bolts
I thought the seal installer and seals was only if I start to pull the axle which would be for the purpose of the ujoint? Or is it just good practice to replace them?
I replaced my d/s hub earlier this year with this Timken part number. As Z stated you need a quality pair of snapring pliers - highly suggest snap on part number SPRC9000A. $30 something US$ well spent IMHO. The Timken hub assembly only comes with the o-ring. My truck had around 171k miles on it and i used some wd40 blue torch penetrate oil on the 4 bolts a few days prior to removal. My lockout hubs werent too bad, so just cleaned up the seals and regreased some. About a 2 hour job. I had done this side a year before and funds allowed only a cheap brand which went out in 8 months. Also i replaced the hub mounting bolts/nuts. Long winded but have more time to write being down after elbow repair.
I'm going to be the odd guy out here, but I've had great luck with 2 separate suppliers off ebay - Detroit Axle and AM Autoparts (based in Canada).
Their hubs are inexpensive, around $100 but come with good warranty. Before anyone jumps on the "its cheap junk" bandwagon - I ran Detroit Axle hubs on my 02 F350 for 2 years and they withstood carrying a 1,000lb V Plow for both winters. I sold the truck and they were still in great shape with no play or noise. I bought them as a test figuring for the money if they lasted one winter than it would be worth it rather than spending $300 on a Timken.
1A our site Vendor says they have good luck with the off brand unit they sell
Me I have 115,000 miles on my OEM Timken and that's running 37's so they earned my repeat loyalty I have a full set in boxes ready to go when the time arises
I do add grease to mine when I service the brakes or seals
We carry Timken wheel bearings for your truck. If you enter in your postal code into the get shipping rates on the product page, the system will calculate it for you. Here's a link to them for your 2006 F350
but Rockauto isn't a site sponsor so they are dead to Me ;-)
also have you seen what the warranty is ? 1A takes the Timken 1 year ( same 1 year Rock auto passes to you )
and self covers it for a lifetime that = forever ;-)
Hi all... im looking to replace my hub...but ive seen where you need to use either coarse or fine thread..im assuming its for the mounting of the hub?..is there a way to tell, without disassembly??... thanks
ps.. I have an 04 f350 4x4 srw long bed.
Thanks 1a... what a pita... ill be looking into it.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
