after market cat - Ford Powerstroke Diesel Forum
Old 02-15-2007, 10:30 AM
after market cat
Do we have a source for a larger diameter cat?
Old 02-15-2007, 01:37 PM
Most people just delete the cat. If you have to go through and inspection yearly it only takes about 15 mins to put the cat back on.
Old 02-15-2007, 02:02 PM
cut off the cat i got 4" straight from the turbo back and it sounds great
I put the muffler on but didnt like the sound to beepbeepbeepbeep quiet
Old 02-15-2007, 03:53 PM
I'm looking for a 4" cat. Is the factory exhaust 4" on the F550?
Old 02-15-2007, 05:25 PM
BIG TRUCK, SMALL DRIVER
It should be 3 1/2"
Old 02-15-2007, 05:48 PM
The cat inlet and outlet is 3.5. All you have to do is cut off enough of the in and out to make it 4 inches then weld it to the new 4 inch pipe. Problem solved.
Old 02-16-2007, 04:55 AM
Thanx
Doh! Cutting and welding 4" flanges should work. Thanx. I wonder what the I.D. on the factory cat is? Is is stainless?
It wouldn't work to weld on new flanges if the I.D. is < 4".
