Engine Heat-Up - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-14-2007, 02:26 AM Thread Starter
Engine Heat-Up
I have had my truck for about 2 weeks now and have observed the engine as it warms up. The transmission temperature meter indicates near normal temperature before the engine temp meter comes off the peg. My last truck (2004 GMC sierra 2500HD 6.0 l) had a temp meter on the transmission as well and would never indicate anything until a load was placed on the transmission. I know that a diesel will not really warm up sitting in the drive but why is the transmission temperature increasing while it is sitting in the driveway??? Is this normal. I had a thought that may be the sensors were mis-wired...kind of out there but I'm sure stranger things have happened.
JR
Metallitruck is offline
post #2 of 12 Old 02-14-2007, 03:27 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
ive never watched that close ,but if its stays in normal range i wouldnt sweat it , ,if a diesel engine sits at idle ,it will actually cool down if at normal temp ,when cold in the morning i can see trans heating up slightly faster than engine
ITS STOCK
SCUFFY828 is offline
post #3 of 12 Old 02-14-2007, 03:41 AM
06F250FX4's Avatar
That was the same thing I was thinking about mine. The trans gauge shows the trans warming up while at idle, but the gauges can't be wired backwards, as the engine is definately not warm. I have never seen a trans warm up at idle, but who knows.
06 F-250XLT FX4. AccuFab Elbow, MBRP 4" exhaust w/ no kitty, AMSOIL/Injen Intake, IssPro Gauges in overhead mount, SCT X3 Tuned by Innovative, Edge Insight in dash pod, BYPASS OIL FILTER, ZooDad mod,
06F250FX4 is offline
post #4 of 12 Old 02-14-2007, 07:19 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 30 Post(s)
Feedback Score: 4 reviews
The Ford trans temp sensors are set up solely on a time basis. They are more of an idiot light to tell you when you've cooked your tranny (they show HOT at like 250*F). My Dads chevy warms up the same thing that my autometer shows me in my truck. That's why they show that they warm up at idle, autos will not warm up unless driven. The proof to that is, after I installed my autometer tranny temp guage, I could see that, what I was told by a powerstroke guru from ATS was true.
I also read that the oil pressure sensor only needs to sense 7.5 psi to show "normal" pressure. I'm thinking of replacing all of my guages so that I have some peace of mind.
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #5 of 12 Old 02-14-2007, 08:15 AM
100% normal. Automatic transmissions will start to warm up as soon as you start your engine. The input shaft of the transmission drives the oil pump and just the fact that it is doing it's job will cause the fluid to heat up. The guage is not measuring the temperature of the transmission, it is measuring the temperature of the transmission fluid.
Larry
2006 F350 King Ranch CC DRW 6.0PSD TorqueShift
Dk. Copper / Tow Command / Tow Boss
Power Slider / Power Pedal Adjust
OEM Bed Liner / SportsMaster Rollup Tonneau
15K Fifth Wheel Hitch
2006 Keystone Everest 345S Fifth Wheel
2006KR is offline
post #6 of 12 Old 02-14-2007, 08:19 AM
2006PSDSD's Avatar
Quoted: 30 Post(s)
So, why does my autometer show a completely different temp than the stock one?
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #7 of 12 Old 02-14-2007, 08:34 AM
Ford's trans temp guage isn't calibrated to show actual temperature. It works similar to the water temp, oil pressure, etc. As long as what ever is within normal operating conditions, the guages will show normal, with some variation in the water and trans temp unless you get out of the normal operating range. I've seen my water and trans temp climb a bit when pulling my fiver up a long grade, then immediately return to the center of the guage when starting down the other side.
The oil pressure guage is nothing more than an idiot light with a needle on it.
Read an outstanding article as to why the mfg went the way they did with the guages. Their example went something like this: A driver was told that the water temp was supposed to 195 degrees. All of a sudden, they look down and it's reading 200 degrees (still well within normal parameters) .... they panic, run to their dealer screaming, my engine's too hot. So the dealer tweaks the guage a bit, and a couple days later, the same person notices that now the temp is only 190. Back to the dealer ... my engine won't warm up ... never ending cycle. The installed guages are a reference only. When the temp is 180 or 210, the guage shows in the normal range, so the freaky driver doesn't go nuts and drive the dealer up the wall.
Larry
2006KR is offline
post #8 of 12 Old 11-21-2009, 04:55 PM
My edge evolution shows oil temperature and coolant temperature. I have been told the max spread between the two is 25 degrees. I am exceeding that by 30 plus degrees when climbing long hills and especially when towing my fifth wheel. Engine oil cooler problem? How do you diagnose that? Without the Edge gauge the truck would not have told me I had a problem...2006 6.0 superduty
B-Dawg is offline
post #9 of 12 Old 11-21-2009, 07:44 PM
MoyockPowerstroke's Avatar
IIRC...the variance is only 10'F between the two. Anything more is a sign of potential oil cooler failure. I great remedy for this concern is to add a coolant bypass filter to remove casting sands that clog up the coolers. As for the previous comments concerns...I whole heartedly agree with the theory of why Ford decided to go the way they did with their analog gauges...otherwise they would have just as well given us too much info by adding Mulitiple digital PID info (i.e. Edge Insight, too many to note...) right from the factory , but they didn't and we know why...too much knowledge for some customers to deal with. I say get gauges...either traditional analog or modern digital (multi-PID) all-in-one gauge. I see 190'F ECT and 200 'F EOT as a daily driver not towing.
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
post #10 of 12 Old 11-21-2009, 07:45 PM
Oh yeah...Tranny Temp (or TFT)...is 156-160"F (again not towing).
