I'm just waiting on the welder to get back (I want nice neat welds! ) before I get mine done.
I am using a freeze plug to block off the exhaust, from entering the cooler and I made a blank to put in where the exhaust enters the intake. The blake is made out of a .010 stainless steel shim. I just used the gasket as a template. Easily removable if needed.
Oh! It cost me $1.30 for the freeze plug. Saved $500+...
and a big headache after it burns through. maybe you will get lucky but for some of us it just isnt worth doing things twice.
i hate taking things apart more then once and if i dont have the money (which im not saying you dont) then i dont touch something till i do. FCDP's kit is worth every penny IMO |
A properly welded cooler (ie w/ proper metal, proper weld techniques, and welded at both ends) will work. Plain and simple. You really should also get a tune that will properly adjust for no exhaust gas recycle. It is the most eficient thing to do for your combustion system (and there are a lot of parts that depend on the cleanest burn possible). Past that, folks are paying extra for: 1. insurance against "low probability" failures (ie the plates or welds failing) 2. looks 3. advertising Last edited by bismic; 08-02-2009 at 08:12 PM. |
well imo if you got the time, patients, and money (to do it again if it fails) then go for it! unfortunately i do not have any of the three..... although i do know about welding. i agree with Bismic that if done correctly THE WELDS should hold. im not a mech though so i can just say that its yours do with what you will.... my 03 6.0 is going to get out of the shop tomorrow.. and im not trying to sell anyone on anything. but i put an full egr delete from liberator and its got warranty, again no patients!! but hey we all have downfalls. none of us like to be told were wrong but .010 is pretty thin and welds die from vibrations........
I have a friend that is welding a spare up-pipe for me w/ 1/8 inch stainless plate. I personally would never use a freeze plug.
wow thats the root hot fill and cap all at once. but the pipe is holding pressure not try to stop it........
like v556 said thats just my two pennies
Spartan Phalanx with Aggressive Street Economy tune. EGR = OFF! (EGR Duty Cycle = 0%)
